Calculate Magnitude of Electrical Field | Electron Acceleration
The magnitude of the electrical field exerted on an electron accelerated from rest for 10E-9 seconds by a force of 8E-15 N is calculated using the equation E=F/q, resulting in a value of 5E4 N/C. The charge of the electron is 1.6E-19 C, which is essential for this calculation. To determine the speed of the electron after the acceleration period, the formula v = at is applied, yielding a final velocity of approximately 8.78E-7 m/s. The mass of the electron, 9.11E-31 kg, is used to find the acceleration from the applied force.
  • Understanding of Newton's second law of motion
  • Familiarity with the concept of electric fields
  • Knowledge of basic kinematic equations
  • Ability to perform calculations involving fundamental physical constants, such as the charge and mass of an electron
  • Study the relationship between force, mass, and acceleration in detail
  • Learn about electric field calculations in different contexts
  • Explore kinematic equations for uniformly accelerated motion
  • Investigate the properties and behavior of subatomic particles, particularly electrons
Physics students, electrical engineers, and anyone interested in understanding the dynamics of charged particles in electric fields.
UrbanXrisis
An electron is accelerated from rest for a time of 10R-9 seconds by a uniform electrical field that exerts a force of 8E-15 N on the electron. What is the magnitude of the electrical field?
What equations should I use? There's E=F/q and E=kQ/r^2 They both don't work.
The speed id the electron after it has accelerated for 10E-9 seconds is most nearly? How do i calculate this?
Why doesn't E=F/q work?
As far as the speed goes, it's a particle moving with constant acceleration. The fact that it's an electron doesn't really have anything to do with anything at this point. You've got a particle of mass m (if you can't remember the mass of an electron, you should be able to look it up quickly), accelerated by a force F. That means its acceleration is a = F/m. If you want to find velocity given a constant acceleration and the time of the acceleration, you just use v = v(0) + a*t (here v(0) is given as 0).
To calculate the magnitude of the electrical field, we can use the equation E=F/q, where E is the electrical field, F is the force exerted on the electron, and q is the charge of the electron. We are given the force (8E-15 N) and the time (10E-9 seconds), so we can rearrange the equation to solve for E:
E = F/q = (8E-15 N)/(1.6E-19 C) = 5E4 N/C
So the magnitude of the electrical field is 5E4 N/C.
To calculate the speed of the electron after it has accelerated for 10E-9 seconds, we can use the equation v = at, where v is the final velocity, a is the acceleration, and t is the time. Since the electron starts from rest and accelerates for 10E-9 seconds, we can plug in the values:
v = (8E-15 N)/(9.11E-31 kg) * 10E-9 seconds = 8.78E-7 m/s
So the speed of the electron after it has accelerated for 10E-9 seconds is approximately 8.78E-7 m/s.
  • · Replies 23 ·
