| New Reply |
Monochromatic and Coherent light |
Share Thread | Thread Tools |
| Sep3-07, 12:47 AM | #1 |
How can the same source of monochromatic light produce 2 waves that are incoherent or coherent for that matter? (Is this even a valid question?)
What does coherence really mean beyond the definition of "waves that have a constant phase difference" could anyone clarify this? thanks. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep3-07, 01:23 AM | #2 |
Welcome to PF, Doubledouble.
You must be a fellow Canuk, since nobody else would have clue about what your name means. ![]() Essentially, the term 'monochromatic' just means that all photons involved are of the same frequency. (In casual useage, it just means the same colour, but includes a range of very similar colours.) Coherency means that the monochromatic EM waves are synchronized so that all 'crests' and 'troughs' are aligned. As a visualization, let's assume that you have a vector-based drawing programme similar to Illustrator or Coral Draw. Draw a sine wave that represents a particular colour such as the red produced by a chromium atom 'lasing' in a ruby crystal. Now hold down 'Shift' & 'Option' at the same time and drag the line down a tad. Click on 'Repeat Transform' a few times, and you'll have a representation of a coherent beam (laser). To compare that to a source that's merely monochromatic, randomly select any of the resulant clone lines and move them around and rotate some of them at ambiguous angles. The colour will still be the same, based upon the shape of the waves, but the orientation won't be coherent. I know that this is a half-assed explanation, but I hope that it serves as a base for further understanding. |
| Sep3-07, 12:14 PM | #3 |
Recognitions:
Truly monochromatic point sources can't produce incoherent light.
True monochromatic light has a delta-peak shaped fourier transform, which in turn means, that the wave shows the same amplitude and a well known phase over an infinite range. So the phase difference is always known. In reality, there are no truly monochromatic light sources. They all show a certain line width and are therefore at least composed of a narrow frequency range (and do not show infinite length). Due to the superposition of several waves the phase of the wave train is predictable for short times, if you know the phase at some moment, but not for longer times. So from a classical point of view temporal coherence is a measure for the predictability of the phase information and thus also for the ability of the light to show interference. In quantum optics coherence time is also the timescale, on which effects like bunching occur. |
| Sep3-07, 06:12 PM | #4 |
I don't know where the hell you came from, Cthugha, but welcome aboard. Nice post.
| Sep6-07, 12:26 AM | #5 |
Do two waves have to be of the same frequency for them to be coherent as well?
| Sep6-07, 08:59 AM | #6 |
Yes—otherwise the crests and troughs can't line up along the length of the beam.
| Jul31-09, 09:05 PM | #7 |
can waves be of a constant phase difference but having a different frequency?
| Aug2-11, 04:19 AM | #8 |
Hey guys,
i was confused by this aswell, and no explanation has allowed me to truly understand the difference. I found this image online which showed me the difference and thought i might share it with everyone else:
| Feb26-12, 01:17 PM | #9 |
[QUOTE=Cthugha;1417575]Truly monochromatic point sources can't produce incoherent light.
http://agamemnon.cord.org/cm/leot/co...04/m1-4f13.jpg we can have temporally coherent waves which means monochromatic, but not spatially coherent. is this what the link says or am i confused? |
| Feb26-12, 04:09 PM | #10 |
Recognitions:
That post was 5 years old...
However, indeed the post above focused on temporal coherence. Spatial coherence depends on the angular size of a light source as seen from some point, so it is a bit fishy as the spatial coherence of a light source can depend on how far you are away from it. As a rule of thumb point-like light source have ideal spatial coherence. |
| Feb27-12, 01:37 AM | #11 |
Thank you for answering a question concerning a 5 year old post My effort to understand interference and diffraction is 2 months old As a rule of thumb point-like light source have ideal spatial coherence. This is why we use the slits in interference, isn't it ? What do we rally need in order to get the interference pattern, temporal or spatial coherence, or both? if we use a slit we get the same phase for one instant, the instant the wave exits the slit, but if the light is not monochromatic how is this phase going to be the same at later instants? How did Young produce an interference pattern since he had no monochromatic light? How did he obtain a constant phase difference? I bombarded you with questions , sorry
| Feb27-12, 03:21 AM | #12 |
Recognitions:
A good measure of how much spatial coherence you have is the angular size of the source as seen from some point. Just imagine you have an extended light source and draw a line from each point of the light source to your position. Now take the longest and the shortest of these lines. You will find that these lines also correspond to different angles. The smaller this difference in angles is, the higher your spatial coherence will be. Now repeat the same procedure for two different positions: One very close to the sample and one very far from the sample. You will notice that the difference in angles is very large close to the light source and very small far from the light source. That means that seen from a huge distance the same light source seems more point-like and therefore will also have higher spatial coherence. |
| Feb27-12, 05:16 AM | #13 |
thank you so much
you explained it extensively and clearly
| New Reply |
| Thread Tools | |
Similar Threads for: Monochromatic and Coherent light
| Is there such a thing as in-phase and coherent white light? | General Physics | 5 | ||
| elementary astrophysics - monochromatic flux? | Introductory Physics Homework | 0 | ||
| monochromatic flux expression? | Astrophysics | 1 | ||
| intensity of a plane monochromatic light wave | Advanced Physics Homework | 1 | ||
| How can a non-resonant monochromatic light induce an atomic transition? | Quantum Physics | 3 | ||
