What is the vertical height between two climbers?
  • Thread starter Thread starter afcwestwarrior
    Height Vertical
The problem involves a rock climber throwing a first aid kit to another climber at a height, with the initial velocity and angle of projection provided. The goal is to determine the vertical height between the two climbers based on the motion of the kit.
  • Participants discuss resolving the initial velocity into horizontal and vertical components and question the use of the correct vertical velocity in calculations. There is an exploration of kinematic equations and the effects of gravity on the kit's motion.
Some participants have provided guidance on resolving the initial velocity into components, while others have attempted calculations using different values. There is a mix of confirmations and questions regarding the accuracy of the calculations, indicating an ongoing exploration of the problem.
Participants note the importance of correctly identifying the vertical component of the initial velocity and the effects of gravity in their calculations. There is an acknowledgment of previous misunderstandings regarding the values used in the equations.
afcwestwarrior
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 11 m/s at an angle of 65 degrees above the horizontal. At the instant when the kit is caught, it is traveling horizontally, so it's vertical speed is zero. What is the vertical height between the 2 climbers.
Initial Velocity=11 m/s
Angle above horizontal=65 degrees
Vertical speed=0
equations of kinematics
Please show some work and effort on one's part.
Determine the horizontal and vertical velocity components.
The horizontal velocity is constant if one ignores air resistance. The kit decelerates as it travels vertically.
Refer to -
http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html#tra5
Here is what I did. I used the equation y=h=Vy^2 - Voy^2/ 2 (Ay)
Then I used the values I had h=(0m/s)^2 - (11 m/s)^2/ 2 (-9.8m/s^2) = 6.1 meters
The answer is 5.1 meters what did I do wrong
vy0 is not 11 m/s.
v0 = 11 m/s.
Resolve v0 into vy0 and vx0
Think about sin and cos of the angle with respect to horizontal.
ok Vy0=11 sin 65=10 m/s
and Vx0=11 cos 65=4.6 m/s
Now what do I do
Ok so it's h=0 m/s)^2 - 10 m/s) ^2/2 *-9.8 m/s^2=5.1
Did I do it right
Yes! :cool:
Thank you Astronuc. It feels good learning how to solve a problem. Instead of just writing down the answer.
Thanks!
Thanks so much, I had the same problem. Ironically, I had split it up into components already, just for some reason I hadn't added it into the formula as my VoY, I was still using the old Vo vector.
Thanks!
  • · Replies 38 ·
20K
