Why Was Millikan's Oil Drop Experiment Not Conducted in a Vacuum?
  • Context: Undergrad
  • Thread starter Thread starter mbrmbrg
    Drop Experiment Oil
The discussion centers around Millikan's oil drop experiment, specifically questioning why it was not conducted in a vacuum and how the mass of the oil drop was determined. Participants explore the implications of air resistance and terminal velocity in the experiment's methodology.
  • One participant questions why air resistance does not appear in the equation used to derive the charge of the oil drop, indicating confusion about the experiment's methodology.
  • Another participant suggests that Millikan may have used the volume of the drop and its density to compute mass, questioning the validity of the terminal velocity approach.
  • A different participant asserts that terminal velocity was indeed used to calculate the mass, claiming that the incorrect value obtained was due to an error in the viscosity of air.
  • It is proposed that conducting the experiment in a vacuum would render the measurement of mass impossible, as the speed of the drop would be independent of its mass in such conditions.
  • One participant shares personal experience, stating that measuring the diameter of the drops visually is challenging, especially since the drops are very small and difficult to catch in a stationary position.
  • There is a humorous remark about the difficulty of repeating Millikan's experiment, comparing it to the challenges of measuring gravitational constant G.
Participants express differing views on the methodology of the experiment, particularly regarding the use of terminal velocity and the implications of conducting the experiment in a vacuum. No consensus is reached on these points.
Participants highlight limitations in measuring small drops and the challenges of visual observation, as well as the dependence on the viscosity of air for accurate results. These factors contribute to the complexity of replicating the experiment.
mbrmbrg
My chemistry professor was discussing Milikan's oil drop experiment today, and she said that he determined the mass of the oil drop by measuring its speed as it fell. (I found this further description online) If that's the case, why doesn't air resistance appear in the equation Eq=mg from which e was derived?
I guess what's really bugging me is why, in the name of all that phyisicists hold dear, was this experiment not conducted in a vacuum?
~Malka
Oh ho! This site purports that Millikan used the approach I assumed would have been taken--get the volume of a drop and compute mass by using density. Is the terminal velocity thing an urban myth?
He used the terminal velocity to calculate the mass of the drop - in fact the reason he got the wrong value was that he had the wrong viscosity of air.
The reason for not doing it in vacuum is simply that in vacuum the speed of the drop is independent of it's mass and so there is no way to measure the mass. The terminal velocity technique is a very clever method of measuring the mass of a very small object.
ps. Don't ever try and do this experiment as a lab project, it is even worse than Cavendish's G measurement to get right!
That sounds like the voice of experience speaking, and I agree (about both experiments).
The idea of measuring the diameter using the telescope seems far fetched. From my memory of doing it, the only drops that were "catchable" were so small they appeared as points in the telescope. And anyway it's impossible to get the drop perfectly stationary to measure it visually.
It would be impossible to do this is a vacuum. You have to "catch" a drop by adjusting the field as it drifts through your field of view. If you lose sight of it, you never get to see that particular drop again. Ideally having caught a drop, you can do repeated experiments on it before you lose it. You don't set the field to zero to measure the terminal velocity, just change its value by a small amount so the terminal velocity is slow enough to measure.
As amazon.com would say, "People who enjoyed pushing pieces of string uphill will also like repeating Millikan's experiment" :smile:
whoa... scary. Thanks!
  • · Replies 28 ·
  • · Replies 16 ·
