Can a magnetic field be shielded passively?
The discussion centers around the possibility of passively shielding a magnetic field using various materials. Participants explore different methods and materials that could be employed for shielding, including superconductors and high-permeability materials, while considering practical applications such as protecting a compass from interference in a vehicle.
  • Experimental/applied
  • Some participants propose that superconductors can exclude magnetic fields, but they require very low temperatures to function effectively.
  • Others mention that common materials with high permeability, such as mu-metal, can be used for shielding, although they may be expensive.
  • A participant suggests using conductive metals to shield against alternating magnetic fields, as these can induce currents that cancel the original field.
  • There is a discussion about the effectiveness of encasing a compass in a superconducting material, noting that it would shield the compass from both local and Earth's magnetic fields.
  • One participant shares a practical approach of placing conductive metal between a compass and the source of interference to mitigate effects.
  • Another participant considers the design of a shield, suggesting a spherical shape for optimal shielding, while expressing concerns about the compass's functionality if overly shielded.
Participants express a range of views on the effectiveness of different materials and methods for magnetic shielding, with no consensus reached on the best approach. Some agree on the use of specific materials, while others raise concerns about their practicality and effectiveness in real-world applications.
Limitations include the dependence on specific conditions such as temperature for superconductors and the effectiveness of materials in different types of magnetic fields (static vs. alternating). The discussion does not resolve the complexities involved in achieving effective magnetic shielding.
This discussion may be of interest to individuals involved in robotics, electronics design, or those seeking to understand magnetic shielding techniques in practical applications.
mreznicek
Friends:
Can a magnetic field be shielded somehow by a passive material?
i.e. can I wrap a strong magnet in some thin material and impede the B field outside?
Thanks amigos! -MigsP.S. This is not a homework question! I finished M.E. a long time ago!
Yes -- superconductors exclude magnetic fields from penetrating, at least up to a limit.
Hi Genneth:
So what is a common household superconductor with which I could shield say my compass as it sits on the dash of my car so that the dash electronics don't affect it?
Migs
mreznicek said:
Hi Genneth:
Migs
Unfortunately, known superconductors need very low temperatures to work. If you've got some household ones, please tell! As far as shielding goes, a compass encased in a superconducting box wouldn't read *any* magnetic field, as the Earth's would be shielded as well. Added to that, I think superconductors are always opaque...
You can also use any material with a high permeability.
The most common one is a special nickel alloy called mu-metal, I imagine it is expensive stuff - I've only ever used it in fancy physics experiments.
The normal way of sheilding out local constant fields is called hard iron correction and just involves positioning small magnets around the compass to cancel the effecs of the local field. If you see an old ships compass this is what the large metal balls around it do.
Thanks for the comments amigos! I kinda figured this was the case. I'ts always nice to have people in the know tell you exactly how it is ;) Migs
In many industrial applications, magnetic fields are shielded by conductors. Try placing a piece of metal (any conductive metal) between your compass and the suspected origin of the interference. For example, a bit of flashing on the dashboard (shiny side down, of course).
mreznicek said:
Friends:
Yes, about any metal works well if it is an alternating field. If it is a fixed field then use mu-metal, or a ferromagnetic metal.
Any metal that is a conductor works well for alternating fields because an alternating field induces current in nearby conductors that it out of phase by 180 Degrees, therefore canceling the original field.
Good to know Eddie. I'm making a small 10x10cm robot vehicle and wanted to isolate the compass sensor from the electronics and motors. Another option will be to put the sensor on a small mast. -Migs
well, here's my thinking:
it would have to have a 'sphere' shaped 'shield' to do the best job
but, the most critical factor is that since you're trying to 'shield' the magnetic field, I don't think your 'compass' is going to work too well
you may want to try to 'shield' the other components
  • · Replies 17 ·
