Question: What is the average of seven rolls of 3d8 in a PnP RPG?
  • Context: High School
  • Thread starter Thread starter Monoculus
    Dice
The discussion revolves around calculating the average results of rolling 3d8 (three eight-sided dice) seven times in the context of a tabletop role-playing game (PnP RPG). Participants explore the implications of randomness in dice rolls and how averages can be applied in game mechanics.
  • One participant asks for the average of rolling 3d8 seven times, acknowledging the randomness of each roll.
  • Another participant calculates the average for a single roll of 3d8 as 13.5, leading to a total average for seven rolls of 94.5.
  • Some participants note that while individual rolls will vary, the average outcome remains consistent at 4.5 for a single die.
  • There is discussion about the distribution of possible outcomes when rolling 3d8, with one participant mentioning a bell curve distribution across the results from 3 to 24.
  • Concerns are raised about the accuracy of probability calculations for the highest rolls, with participants questioning the reported percentages.
  • Another participant shares random sampling results showing average rolls for seven sets of 3d8, providing specific averages for each stat.
  • Participants discuss the implications of these averages for creating a point-buy system in the game, with one participant explaining their method for adjusting point totals based on rolled stats.
  • Technical details about a software tool for calculating probabilities and averages are shared, including a script for simulating rolls.
Participants generally agree on the average value of a single roll of 3d8, but there are multiple competing views regarding the interpretation of probabilities and the implications for game mechanics. The discussion remains unresolved on some technical aspects of probability calculations.
Some calculations and assumptions about probabilities may depend on specific interpretations of the rolling mechanics and the context of the game. There are unresolved questions regarding the accuracy of reported probabilities and the implications for game balance.
Game designers, tabletop RPG enthusiasts, and those interested in probability and statistics in gaming contexts may find this discussion relevant.
Monoculus
This is for a PnP RPG I am creating... I've looked around for places on the internet, but haven't really found anything so I figured I'd go to the source. ;)
QUESTION: I'm rolling 3d8, (3 eight-sided dice), seven times. What is the average of each roll? Because these are dice, I figured each average would be different because the rolls would be random with each roll.
If someone could help me with this, that would be great. I know it's probably just a simple question, but I can't seem to figure out how to solve it.
The average for each die would be 4.5 . So for 3 dice it would be 13.5 . So for 7 times it would be 94.5 .
That's not quite the answer I was looking for, but still helps in my creative process.
I think I was just over-thinking a bit.
When you roll 3d8 seven times, what would the results be for each roll? I now realize that it would be different each time, obviously. I tend to over-analyze things, I think that's what happened LOL
Appreciate your time though, thanks again.
The outcome will be different but the average of all the outcomes will be, as nicktacit said, 4.5.
Tell us what you are trying to do. Are you dropping some dice and summing the others? Are you looking for the likelihoods of the highest, second highest, ... dice being certain values?
For example, the highest roll is 24 with probability 1.36%, 23 with probability 3.98%, 22 with probability 7.55%, ...
Also, there are 512 possible unique results, distributed as a bell curve across the numbers 3 though 24.
You want to build a matrix like this:
Code:
 sum  rolls                        chances   percent
  3   111                           1/512     0.2%
  4   112 121 211                   3/512     0.6%
  5   113 122 131 212 221 311       6/512     1.2%
 23   788 878 887                   3/512     0.6%
 24   888                           1/512     0.2%
You sure about these numbers?
There is only one way to roll 24, thus the chances are 1 in (8^3) = 1/512 = 0.195%.
Quite sure. I'm reporting the probabilities across all 7 sets -- the probabilities for a single roll of 3 8-sided dice is easy (and symmetric).
Oh I see. So, 0.195 x 7. Gotcha.
Well, subtracting off the double-counting, yes. At least one 24 out of the 7 sets has probability 1-(511/512)^7. The others are a little trickier, but not bad.
Waitaminute. Won't your numbers add up to 700%? You've only listed 3 numbers and you're already covering off 13% of the results.
I have seven stats, (Strength, Dexterity, etc). For each stat, you roll 3d8 to get your stat score.
What I was trying to do was figure out what numbers would be rolled if you initially rolled 3d8 seven times.
I would then take my results and list them in the book as an example for the reader. I was also going to use the results to create a point-buy system.
The numbers will add to exactly 100%. Consider how unlikely it is to have one's highest roll be a dozen or less -- 0.18%, within rounding.
(Did you see post #10? We posted at nearly the same time.)
What's the seventh, luck? Comeliness? As for point-buy, the probabilities won't help you -- you need to decide how much each is worth in the game. Inverse cumulative probabilities would be silly -- you wouldn't want a 24 to be worth four times what a 23 is worth, would you?
This is my end result:
I took the average of a 3d8 roll (13.5) and rounded it to 14.
14 x 7 stats = 98 points for stat distribution
I added 2 more points to give the player a very small edge, so I'm at 100 points total now.
My 100 points were decreased to 79 because all stats are automatically defaulted to 3 when using the point-buy system, (7 stats x 3 = 21 points initially used). I then dropped the 79 down to 75 so I would have a more generalized number.
If a player chooses to roll for their stats, they will more than likely get the better results. If they want more control over their stat totals, then they sacrifice the possibility of getting better dice rolls. I'm satisfied with the way this works, for now anyway; all things are subject to change as we explore more game mechanics.
The seventh stat is Charisma. The game is skill-based, so skills will be dependent upon the character's attributes.
Random sampling (100,000 sets of 7x3d8) shows the average roll is (19, 17, 15, 13, 12, 10, 8). To two decimal places (I'm not confident the others are accurate), that is
(18.82, 16.59, 14.95, 13.50, 12.05, 10.41, 8.15)
Do you have a software tool for calculating that? If so, can I have the link? :D
And thank you, I'll use those numbers instead of what I rolled LOL
I was just wondering which stats you has that differed from the D&D-inspired Str, Dex, Con, Int, Wis, Cha.
The average point buy is of course 73.5. 46% of random rolls will have at least a 75 point buy; the remainder will have less. Of course players who get to choose their own stats will make them effectively better by careful placement.
I just made a short PARI/gp script.
This table is the number of rolls (out of 512) that are at least 1, 2, 3, ..., 24.
rtable = [0, 0, 1, 4, 10, 20, 35, 56, 84, 120, 162, 208, 256, 304, 350, 392, 428, 456, 477, 492, 502, 508, 511, 512]
This rolls the 3d8 randomly:
roll() = local(r); r=random(512);for(i=3,24,if(r<rtable,return(i)))
This takes seven rolls and sorts them:
rseven() = vecsort([roll(),roll(),roll(),roll(),roll(),roll(),roll()])
This takes the average of the lowest-of-7 of 100,000 rolls:
sum(i=1,10000,rseven()[1])/10000.
To get the average of the second-lowest, use the above line with a [2] instead of a [1].
If you want to download PARI, you can just copy/paste what I wrote.
  • · Replies 16 ·
  • · Replies 41 ·
21K
  • · Replies 32 ·
27K
