What is the Relation Between Velocity and Complex Refractive Index?
The discussion revolves around the relationship between velocity and the complex refractive index in various media, particularly focusing on the implications of the imaginary part of the refractive index. Participants explore theoretical aspects, practical observations, and the implications for phase and group velocities in different contexts.
  • Some participants propose that the phase velocity can be expressed as \( v = \frac{c}{\Re{n}} \), where \( \Re{n} \) is the real part of the refractive index.
  • Others argue that the imaginary part of the refractive index contributes a damping factor but does not affect the phase velocity directly.
  • A participant expresses concern about the implications of a small \( \Re{n} \) leading to potentially unlimited phase velocities, questioning the physical meaning of such a scenario.
  • It is noted that while phase velocity can exceed the speed of light, the group velocity remains less than \( c \), which aligns with relativistic principles.
  • One participant mentions that the real and imaginary parts of the dielectric function can approach zero at the plasma frequency, impacting the interpretation of \( v \).
  • Another participant introduces the concept of the linewidth enhancement factor, relating it to the ratio of the imaginary part to the real part of the refractive index, and seeks clarification on its implications.
Participants generally agree that the phase velocity can exceed the speed of light without violating special relativity, as the group velocity remains constrained. However, there is no consensus on the implications of small values of \( \Re{n} \) or the interpretation of the linewidth enhancement factor.
Limitations include the dependence on specific frequencies and the conditions under which the refractive index is measured. The discussion also highlights the complexity of interpreting the physical meaning of velocity in relation to the complex refractive index.
Angelos K
The index of refraction is a complex number if the mediums conductivity is non zero.
n=Re(n)+Im(n)*i
We know that for real refractive index:
v=c/n
How is the corresponding relation for complex n? I would expect (and got from my calculations)
v=c/Re(n),
but since Re(n) may become arbitarilly small (by chosing the frequency of the wave suitably) I distrust the above.
Science news on Phys.org
Your thinking is correct. Actually there is no corresponding relation fo complex part of n. You can simply see the meaning of complex part if you put it in the plane wawe:
[tex]e^{i(kx-\omega t )} ~ where ~ k=\frac{\omega n}{c} ~ and~ n=n_0+i\kappa[/tex]
you get:
[tex]e^{-\omega \kappa x /c } ~ e^{i(kx-\omega t) } ,~ k~ is~ now ~ k=\frac{\omega n_0}{c}[/tex]
So in the phase velocity there is only real part of n. Imaginary part brings you only a damping factor that decreases the amplitude exponentially.
I hope it's was clear enough :)
Thanks! That fine example was precisely what gave birth to my curiosity! But if the relation I got
[tex] v = \frac{c}{\Re{n}}[/tex]
is correct, isn't it strange that, by making [tex]\Re{n}[/tex] small we can achieve virtually unlimited phase velocity? We know that practically zero real part of [tex]n[/tex] can be observed for certain frequencies of EM waves in a medium.
That alerts me, even though there shouldn't be any violation of relativistic principles, since [tex]v[/tex] is a phase velocity.
Thank you again :-)
is correct, isn't it strange that, by making [tex]\Re{n}[/tex] small we can achieve virtually unlimited phase velocity...
no, it's not strange, since the group velocity
[tex] \frac{d\omega}{dk}[/tex]
is still less than c.
The phase velocity is quite often much larger than c in transmission lines (if I am not misstaken this happens in e.g. cylindrical waveguides). But, as olgranpappy pointed out, there is no violation of SR since the group velocity (which is the speed you can transfer information at in this case) is always smaller than c.
Thank you both!
I was aware of the point that there is no violation of SR, but still suprised that v can exceed 3x10^8 m/s by that much. Does anyone know how big v has been observed to become?
Thanks again :-)
if you are asking how small n has been known to get then the answer is zero... both the real and imaginary parts of the dielectric function go to zero at the plasma frequency.
v, in this context, has no other meaning that some quantity which is inversely proportional to n...
Ah, I think I understand where my mistake is: so v cannot be measured directly?
For large enough frequencies I have, too found
[tex]p=\frac{1}{\omega}\sqrt{{\omega}^2-{\omega_p}^2}[/tex]
which, as you said, vanishes at the plasma frequency.
Thank you!
This post reminds me one of mu question. Does anyone know something called linewidth enhancement factor? It is the ratio of imaginary part of refractive index to its real part. I have a feeling that, by writing a plain wave as e^-i(omega * t - k * r) or e^i(omega * t - k * r), this value will have different sign. Could anybody give any comment on it?
Thanks in advance
Thanks in advance
the real and imaginary parts of the refractive index are properties *of the material*, not of the probe which you send into the material and certainly not of the conventions which you use for plane-waves.
That being said, if you are asking how the ratio Im(N(f))/Re(N(f)) (where N is the complex refractive index; [tex]N^2=\epsilon[/tex] where [tex]\epsilon[/tex] is the dielectric constant) changes when f --> -f (where f is frequency) I believe that you can figure it out by the fact that when f --> -f we know:
[tex] Im(\epsilon) \to -Im(\epsilon)[/tex]
and
[tex] Re(\epsilon)\to Re(\epsilon)[/tex].
31K
