It's me again. need somebody to check my answer
  • Thread starter Thread starter cseet
The discussion centers on the analysis of a series RCL circuit with parameters L=6.5 mH, C=3.7 µF, and R=5.5 ohms, driven by a generator with a maximum emf of 197 V. The resonant frequency is calculated to be 6.45E3 rad/s, with I(rms) at resonance when w=7.0E3 rad/s found to be 25.3 A, although this value is questioned. The reactance values X(c) and X(L) at w=7.0E3 rad/s are determined to be 38.6 ohms and 45.5 ohms, respectively. The phase angle is calculated as 51.4 degrees, with guidance provided on converting this value to radians.
  • Understanding of RCL circuit theory
  • Familiarity with angular frequency and resonant frequency calculations
  • Knowledge of reactance (X) and impedance (Z) in AC circuits
  • Ability to convert between degrees and radians
  • Study the calculation of resonant frequency in RCL circuits
  • Learn about the implications of I(rms) at different frequencies in AC circuits
  • Explore the relationship between reactance and impedance in series circuits
  • Practice converting angles from degrees to radians using the formula x = (π/180) * degrees
Students and professionals in electrical engineering, particularly those focusing on AC circuit analysis and resonance phenomena.
cseet
Hi all,
it's me again... sorry but this is the only place where I learn most of my physics from... pls kindly check my answer and for the last part... I found the angle but don't know how to convert it to (rad)... pls guide me...thanks
A series RCL circuit with L= 6.5 mH, C=3.7uF, and R = 5.5ohm is driven by a generator with a maximum emf of 197 V and a variable angular frequency w.
(a) Find the resonant frequency . (Unit: rad/s)
6.45E3 rad/s
(b) Find I(rms) at resonance when w=7.0E3 rad/s . (Unit: A)
25.3 A
(c) Find X(c) when w=7.0E3 rad/s. (Unit: ohm)
38.6 ohm
(d) Find X(L) when w=7.0E3 rad/s. (Unit: ohm)
45.5 ohm
(e) Find Z when w=7.0E3 rad/s. (Unit: ohm)
8.82 phm
(f) Find I(rms) when w=7.0E3 rad/s. (Unit: A)
15.8 A
(g) Find the phase angle when w=7.0E3 rad/s. (Unit: rad)
phase angle = inverse tan ((45.5-38.6) / 5.5) = 51.4
answer: I found the angle to be 51.4 degrees but how do I convert it to unit - rad?
thanks
cseet
If I'm not mistaken this is a conversion between degrees and radians.
[tex]\frac{2 \pi}{360} = \frac{x}{51.4}[/tex]
and solve for x. Don't factor out [tex]\pi[/tex], use it in your answer. For example [tex]x = 0.98 \pi[/tex]
All answers are correct (good job!) except for (b) which I cannot confirm nor deny. I still don't understand the meaning of "I(rms) at resonance when w=7.0E3 rad/s" when the only resonance frequency is 6.45E3 rad/s. If they only want you to find I(rms) at w=7.0E3 rad/s, then the answer should be the same as (f), 15.8A.
