Finding out how many electrons have passed a point in the circuit
The original poster attempts to calculate the total charge that has passed through a point in a circuit given a current of 6.3 kA over a duration of 58 minutes, and subsequently determine the number of electrons corresponding to that charge.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the calculation of total charge using the formula Q = I x t and the conversion of charge to the number of electrons by dividing the total charge by the charge of a single electron.
Some participants express confusion regarding the exponent in their calculations, while others confirm the correct values and calculations. There is an ongoing exploration of potential errors in division and rounding, with no explicit consensus reached on the final answer.
Participants note discrepancies in the expected results and the calculations performed, questioning whether there may have been a misunderstanding or typo in the provided values.
mandos
Calculate the charge which has passed through a point in a circuit when there is a current of 6.3kA for 58 minutes. Calculate the number of electrons passing a point in the circuit.
How to work out the part in blue.
We're told the charge of one electon is "e = -1.6 x 10^-19 C"
Q = I x t
t = 58min = 3480 seconds.
I = 6.3 x 10^3
3480 x 6.3 x 10^3 = 2.2 x 10^7 (rounded up a bit as my college teacher told me to do).
But it's the part in blue I get stuck on. I actually already know the answer (also rounded up slightly I believe) is 1.4*10^26 but it's how I get to that answer using the information "e = -1.6 x 10^-19 C" and "Q = 22 x 10^7"
If someone could show me how to do it, so I can then practice doing so on the other questions I've got and learn it properly. Also, apologies if this is a really moronic question for some of you, browsing around you all seem to be quite intelligent ^^;
Take the total charge... 2.2*10^7C... and divide by charge/electron = 1.6*10^-19C/electron. That gives you the number of electrons.
2.2*10^7 / 1.6*10^-19 gives me 1.375^-12
I can see that 1.375 is rounded up to 1.4 but the power is still -12 and the answer the college teacher has given us is 1.4*10^26
The exponent is 1.6*10^-19. not +19.
I made it from negative nineteen to positive nineteen and got the right answer she said we should get.
So did she make a typo with multiply ten to the power negative nineteen?
No 1.6*10^-19 is right.
[tex]\frac{(2.2*10^7)}{(1.6*10^{-19})}[/tex] should give you 1.375*10^26.
Did you divide correcty?
I'm either incredibly stupid or my calculator is playing mind games.
I'm inclined to believe it's the first one.
Thanks for all your help learningphysics. I've finally got it.
:wink: No prob. happens to all of us.
9K
9K
  • · Replies 31 ·
10K
  • · Replies 20 ·
