Mystery of Polynomials: Is Infinity a Constant?
  • Context: Undergrad
  • Thread starter Thread starter mubashirmansoor
    Strange
The discussion revolves around the behavior of polynomials, particularly the function \( y = x^2 \), as \( x \) approaches infinity. Participants explore whether this behavior implies that the polynomial approaches a constant value at infinity, raising questions about limits and the nature of infinity in mathematical terms.
  • One participant suggests that as \( x \) approaches infinity, the ratio \( \frac{(x+d)^2}{x^2} \) approaches 1, implying that \( y = x^2 \) reaches a constant term at infinity.
  • Another participant counters that \( f(x+d) \) is not generically a multiple of \( f(x) \) and that the limit approaching 1 does not indicate that \( x^2 \) approaches a constant.
  • A later reply emphasizes that while the limit of \( \frac{(x+d)^2}{x^2} \) tends to 1, this does not suggest that \( x^2 \) is bounded above or approaches a constant value.
  • Further contributions note that the ratios of consecutive polynomial values approach 1, but this does not imply that \( f(x+1) = f(x) \) for large \( x \).
  • Another participant points out that the expression \( x^2 + 2x + 1 = x^2 \) cannot hold true for any real value of \( x \), highlighting a misunderstanding in the original claim.
  • One participant discusses the limits in a formal sense, stating that \( \lim_{x \to \infty} \frac{x^2 + d}{x^2} = 1 \), reinforcing the idea that the polynomial does not approach a constant.
  • Another comment addresses the geometric interpretation of derivatives and the distinction between constant increases and infinitesimals, suggesting a confusion in the original argument.
Participants express disagreement regarding the implications of limits and the behavior of polynomials at infinity. No consensus is reached, as multiple competing views remain on the interpretation of these mathematical concepts.
Some participants note that the discussion involves assumptions about the behavior of polynomials at infinity and the nature of limits, which may not be universally accepted or understood.
mubashirmansoor
Isn't this strange!
Hello,
Sometime ago I realized sth strange for most of the polynomials;
For example, [tex]y=x^2[/itex]<br /> <br /> if we take f(x+d) as a multiple of f(x), I mean: f(2)/f(1) = 4 hence 4*f(1) = f(2) so 4 is a multiple of f(1). Now; <br /> <br /> <div style="text-align: center">[tex](x+d)^2/x^2[/itex][/tex]​</div>[tex] <br /> as x approaches infinity the multiple approaches 1 ! <br /> doesn't this means that when y=x^2 and x is an infinitly large number, y reaches a constant term, ie never approaches ininity?<br /> <br /> I'll be thankfull for your help. I hope I've been able to express what I really mean.<br /> Thankyou.[/tex][/tex]
Firstly, f(x+d) is not generically a multiple of f(x). (I'm not sure if you were claiming it was). Secondly, whether or not f(x+d) is a multiple of f(x) has nothing to do with anything here, as you can sesnibly talk about f(x+d)/(f(x) anywhere where f(x) is not zero.
Finally, it is obvious that (x+d)^2/x^2 tends to 1, but this does not suggest that x^2 appraches a constant, merely that x^2 "tends to" (x+d)^2 in some sense, which is intuitive and does not in anyway suggest that either function is bounded above.
Well, sorry for my wrong words, but what I really mean is different, note the following for y = x^2:
f(2)/f(1) = 4
f(3)/f(2) = 2.25
f(4)/f(3) = 1.7778
and so on... as we divide these consecutive terms the result approaches 1 and at some point f(x+1) = f(x) where x is extreamly large...
which means y approaches a constant term when x approaches infinity...
This is impossible, so I'm puzzeled... :)
No. There is no point on f(x) = x^2 where f(x+1) = f(x).
As as a limit where x approaches infinity then they are equal, but for any Real value, they are not. Expressing f(x+1) = f(x) differently, you are claiming x^2 + 2x + 1 = x^2 is true for large values of x. Indeed, if it was true, then for large values of x, 2x+1 = 0. Quite false. Just because in the limiting sense the 2x+1 becomes negligible compared to the x^2 does not mean it is not there.
mubashirmansoor:
You can see that
[tex]\mathop {\lim }\limits_{x \to \infty } \frac{{x^2 + d}}{{x^2 }} = \mathop {\lim }\limits_{x \to \infty } 1 + d/x^2 = 1[/tex]
Clearly,
[tex]\forall \varepsilon > 0,\;\exists x_0 > 0:\forall x > x_0 ,\;\left| {\frac{{x^2 + d}}{{x^2 }} - 1} \right| < \varepsilon[/tex]
Simply choose [tex]x_0 = \sqrt {\left| d \right|/\varepsilon }[/tex]
What it means is that f(x)= x2 and g(x)= (x+d)2, for fixed d, are of the same "order": x2= o((x+d)2) which was clear to begin with since they are of the same degree.
The ratio of F(n) over F(n+1) is going to be smaller as n increases. This is to be expected. So what? It has no bearing on the nature of the infinitesimal.
After all, just n/(n+1) tends to 1, so does the square. We have [tex]lim\frac{n^2}{(n+1)^2}=lim\frac{n}{n+1}*lim\frac{n}{n+1}\rightarrow1*1=1[/tex].
Geometrically, from the standpoint of the derivative we are talking about a tangent between two points that tends to a ultimate of a single point.
From your standpoint, we are looking at [tex]\frac{F(n+1)-F(n)}{1}=2n+1\rightarrow\infty[/tex]
I take this as a case of wholesale confusion between a constant increase and infinitesimal.
ohgodicanthelpmyself
let x = -0.5
but I see what you were going for.
  • · Replies 17 ·
