Spaceship Time dilation problem
The problem involves a spaceship traveling to Alpha Centauri, which is 4 light years away, at a speed of 0.75c. The original poster seeks to determine the travel time as measured from both Earth and the spaceship's perspective, utilizing concepts of time dilation and proper time.
  • The original poster attempts to apply time dilation equations to find the travel times from both perspectives, questioning whether their observations about the measurements are correct.
  • Some participants question the original poster's understanding of the observer's frame of reference, suggesting a need to clarify the application of the equations.
  • There is a discussion about the necessity of calculating the distance as perceived by the spaceship observers and its relevance to the time dilation formula.
The discussion is ongoing, with participants providing guidance on the correct application of the equations and clarifying the perspectives of different observers. There appears to be an exploration of multiple interpretations regarding the measurements of time and distance in different frames of reference.
Participants are navigating the complexities of relativistic effects, including time dilation and the differences in measurements between stationary and moving observers. The original poster's assumptions about the distances and times involved are under scrutiny.
Benzoate
A spaceship departs from Earth for the star Alpha Centauri whic is 4 light years away. The spaceship travels at .75c. Howlong does it take to get there (a) as measured on Earth and (b) as measured by by a passenger on the spaceship
proper time = delta(t')=2D/v
delta(t)=delta(t')/sqrt(1-v^2/c^2)
In part a, the observer is going to the measured that the Earth travels at the speed of light, so I would used the equation , delta=delta(t')/sqrt(1-v^2/c^2)
In part b, the observer on the spaceship is going to measured the proper time and will not notice that the spaceship is traveling closed to the speed of light . so he will used the equation delta(t') =2D/v= 2*(4*light*years)/(.75c)
Are both my observations correct?
You have it a bit backwards. It's the Earth observer who sees the ship move at 0.75c, so the Earth observer simply says the trip takes T = D/V. (Not 2D/V !)
(Note that the distance is 4 light years according to Earth observers; the spaceship observers measure a different distance.)
How do I have it backwards when the observers on Earth who are at rest are going to see the ship approach the speed of light and therefore , in the inertial frame containing the observers of the earth, time will seem slower. For the person
I didn't think I needed to find the distance the passenger on the spaceship measures from the spaceship to the Earth since the time dilation formula contains the proper time interval. delta(t) =delta(t')/gamma
It's certainly true that Earth observers will view the moving clocks on the spaceship as running slow. Thus the travel time according to Earth observers will be longer than the travel time according to the spaceship clock.
It's also true that you don't need to find the distance according to spaceship observers (that's why it was a parenthetical remark). But in order to use the time dilation formula, you need to start by calculating one of the times. The travel time according to Earth observers is easy to find using D = V*T, since you know the distance and speed as measured by Earth observers.
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 21 ·
