Solve Particle Motion to Origin: Mechanics Question
  • Thread starter Thread starter EbolaPox
    Mechanics
The discussion centers on solving the mechanics problem involving a particle of mass m released from rest at a distance b from a fixed origin, with a force described by the inverse square law, F(x) = -kx^(-2). The correct time for the particle to reach the origin is established as t = π√(mb³/8k). The participant initially attempted to solve the nonlinear ordinary differential equation (ODE) m \ddot{x} + kx^{-2} = 0 but shifted focus to potential energy integration, leading to the expression V(x) = -1/x + K. The discussion emphasizes the importance of using separation of variables and suggests a trigonometric substitution for the integral involved.
  • Understanding of classical mechanics, specifically Newton's laws of motion.
  • Familiarity with ordinary differential equations (ODEs) and their solutions.
  • Knowledge of potential energy concepts and integration techniques.
  • Experience with variable substitution methods in calculus.
  • Study the method of separation of variables in solving differential equations.
  • Learn about trigonometric substitution techniques for integral calculus.
  • Explore the implications of the inverse square law in physics problems.
  • Review potential energy and its relationship to force in classical mechanics.
Students and educators in physics, particularly those focusing on mechanics and differential equations, as well as anyone seeking to deepen their understanding of particle motion under inverse square law forces.
EbolaPox
Hi, I'd just like to know if I'm on the right track or a hint or something to help. The problem is: "A particle of mass m is released from rest a distance b from a fixed origin of force that attracts the particle according to the inverse square law:
F(x) = -kx^(-2). Show that the time required for the particle to reach the origin is
[tex]\pi \sqrt{ \frac{mb^3}{8k}}[/tex]
F = ma, dV/dx = -F
Initially, I rather hoped to solve the ODE [tex]m \ddot{x} + kx^{-2} = 0[/tex]
However, this was nonlinear and I didn't know how to solve it analytically.
So, I decided to look at the potential. I know the negative derivative of the potential with respect to x is the force. So, I separated and integrated and got
[tex]V(x) = \int kx^{-2} dx = \frac{-1}{x} + K = \frac{mv^2}{2}[/tex]. I know that when x = b, my velocity is zero (released from rest), so I get the K, the constant of integration, should be 1/b.
So, my idea now was to solve for velocity as a function of x. I then could call velocity dx/dt, separate and integrate hopefully. I then could set my x(t) = 0 and solve for t hopefully. This, however, did not work well. I got
[tex]v = \sqrt{ \frac{2k}{m} * ( 1/b - 1/x)) }[/tex] . Separation of variables (calling v = dx/dt) yielded the recipriocal of that fraction being integrated, which I was unaware of how to do, and did not look simple.
I'm pretty sure I'm approaching this problem in a far too difficult manner. Any hints or suggestions would be appreciated, I don't want a full solution, just a hint in the right direction. Thank you.
Note that you forgot the k factor when you did the integral.
I think you're almost there... use separation of variables in the last part as you were going to... I think a variable substitution will allow you to solve that integral. Might be a trigonometric substitution since the answer has a [tex]\pi[/tex].
  • · Replies 37 ·
  • · Replies 22 ·
  • · Replies 19 ·
