Solving Indefinite Integral: F(x)= \int\frac{1}{t}dt from x to 2x
The discussion revolves around the continuity of the function F(x) defined as the integral of 1/t from x to 2x. Participants explore the implications of the integral's limits and the properties of the natural logarithm in relation to the function's behavior over the interval (0, infinity).
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the continuity of F(x) and the role of the natural logarithm as the antiderivative of 1/t. There are questions about the implications of the integral's limits and the assumptions regarding the domain of x.
The conversation is active, with participants providing insights into the properties of the natural logarithm and its continuity. Some have clarified misunderstandings regarding the integral and its evaluation, while others are still exploring the implications of the function's definition.
There is a focus on the interval (0, infinity) and the assumptions about the values of x, particularly regarding negative numbers and their relevance to the continuity of the function.
rdgt3000
How is this function continuous from 0 to infinity
F(x) = [tex]\int\frac{1}{t}[/tex]dt from x to 2x
I am fairly sure that this equation uses the properties of natural logs to solve.
Also an infinite function has a derivative that is equal to 0.
F'(x)= 1/t
That is about how far I have got in solving this problem. I really can't figure out why I am having such problems with this. I think it has to do with the fact that the interval of the integral is from x to 2x.
Fundamental theorem of calculus. Let f be a real-valued integrable function defined on a closed interval [a, b]. If F is defined for x in [a, b] by
intregral(1/x) from a to x
then F is continuous on [a, b]. If f is continuous at x in [a, b], then F is differentiable at x, and F ′(x) = f(x).
I presume the problem asks to show that F is continuous on (0,infinity) not [0, infinity] - there's a difference, one is true, the other isn't.
I very much doubt that this "has to do with the fact that the interval of the integral is from x to 2x". If you know the anti-derivative, F(t), then the integral is F(2x)- F(x).
I'm more inclined to think that the problem has to do with the fact that you don't know the anti-derivative of 1/t ! If you do, what is it? If you don't, look it up in your textbook!
Sorry I've just been off tonight. Under the attempted solution part I put F'(x)= 1/t . What I meant was the antiderivative was log(t). That one is a no brainer. I'm having some trouble explaining why it's continuous. And yes, it is from the interval (0, infinity), sorry about that. Thank you both for your quick and helpful responses by the way.
What are the properties of the natural logarithm function?
The domain for the natural logarithm is the set of all real numbers and is also differentiable. Therefore the function is continuous from (0, infinity) since the log of any positive number results in an answer that exists, the range is from - infinity to + infinity. I think my problem was from thinking that what if x equaled some negative number, but that is ruled out since the function must occur from (0, infinity). So I am pretty sure I just figured this out, and have also realized that this was a fairly easy question!
The antiderivative of the integrand in the Natural Log. By the Fundamental theorem on calculus, The integral then evaluates to [itex]F(x) = \log_e (2x) - \log_e (x)[/itex].
Can you see a log property that would simplify the RHS to a constant, making F(x) continuous for all real x?
Gib Z has better alluded to what I was aiming at. I assumed that you'd actually evaluated the integral after the help given previously. It should be very apparent what the answer is now.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 23 ·
