Using the Delta-epsilon definition but for two variables?
The discussion revolves around applying the delta-epsilon definition of limits in the context of a function of two variables, specifically f(x,y) = y / (x^2 + 1). Participants are exploring how to approach this problem and clarify the conditions under which the limit is evaluated.
  • Some participants attempt to extend the epsilon-delta definition to two dimensions, discussing the epsilon-neighborhood of a point. Others express uncertainty about how to begin and question the specific limit point as (x,y) approaches what value.
The discussion is ongoing, with participants sharing their thoughts and attempts to understand the application of the limit definition. Some guidance on the structure of the epsilon-delta definition in multiple dimensions has been provided, but there is no explicit consensus on the approach or limit point.
Participants note the need for clarity on the limit point as (x,y) approaches a specific value, which remains unspecified. There is also mention of potential constraints related to the values of x and y in the context of the limit.
pr0me7heu2
I have probably over thought the whole thing... but I can't seem to find any place to start with this one:
Using the formal definition of a limit:
f(x,y)= y / (x^2 + 1) e=0.05
For multiple dimensions you need to extend the epsilon-delta notation to incorporate the epsilon-neighborhood of the point p0 = (x,y), which is the set of all points p such that the distance between p0 and p is less than epsilon.
The limit seems to be 0.
So if [tex]0<|y|<\delta[/tex] and [tex]0<|x|<\delta[/tex].
[tex]\left| \frac{y}{x^2+1} \right| \leq \frac{|y|}{x^2} < \frac{\delta}{x^2}[/tex].
Now use single variable analysis that [tex]\frac{\delta}{x^2}[/tex] can be made sufficiently small.
limit as (x,y) goes to what?
  • · Replies 31 ·
