Solving Problems Involving Ge, Well Lagged Wires, and Heat Flow
This discussion addresses two specific problems involving Germanium (Ge) and heat flow in well-lagged wires. In the first problem, it is established that 30% of the current in a Ge sample is carried by electrons, given their mobility of 3500 cm2/V.s compared to holes at 1500 cm2/V.s. The second problem involves calculating the rate of heat flow along a wire with thermal conductivity defined as K = B + CT, leading to the formula dQ/dt = A/L(T1-T2) {B + C/2 (T1 + T2)}. Key principles include Hall effect measurements and Fourier's law of heat conduction.
  • Understanding of Hall effect measurements in semiconductors
  • Knowledge of thermal conductivity and Fourier's law
  • Familiarity with electrical mobility concepts in materials
  • Basic principles of heat transfer in one-dimensional systems
  • Study Hall effect calculations in semiconductor physics
  • Explore Fourier's law of heat conduction in detail
  • Investigate the relationship between mobility and current in semiconductors
  • Learn about thermal conductivity variations with temperature in materials
Students and professionals in physics, electrical engineering, and materials science who are dealing with semiconductor behavior and thermal analysis in conductive materials.
tigigi
Could anyone gives me some hints of how to solve these problems ?
1. a sample of Ge has both electrons and holes carrying the current. When a hall measurement is done, there's no hall effect. If the mobility of electrons in Germanium is 3500 cm^2/V.s and that of holes is 1500 cm^2/V.s, show that 30% of the current is carried the electrons.
2. a well lagged wire (no heat enters or leaves except at the ends) length L and cross sectional area A has its ends maintained at T1 and T2. The thermal conductivity of the wire K=B+CT where B and C are constants. Show that the rate of flow of heat along the wire is given by dQ/dt = A/L(T1-T2) {B+C/2 (T1+T2)}
Thank you. I appreciate it.
For 1, can one convert mobility into current.
Incidentally 1500/(1500 + 3500) = 0.3 or 30%, but 3500 cm^2/V.s is the mobility of electrons and 1500 cm^2/V.s the mobility of holes, so the electrons move much more readily.
for 2, think about Fourier's law in one dimension.
dQ/dt = - k A dT/dx
and remember k = k(T)
