Average Rate of Change (word problem)
The problem involves calculating the average velocity of a bolt dropped from a height of 320 meters, described by the function s(t) = 320 - 5t², for specific time intervals. The focus is on understanding the average rate of change of the position function over designated seconds.
  • Participants discuss the definition of the time intervals for calculating average velocity, specifically the first, third, and eighth seconds. There is mention of using the formula for average velocity and clarifications on how to apply it correctly.
Some participants have provided guidance on how to set up the calculations for average velocity during the specified intervals. There is an ongoing exploration of the correct interpretation of the formula and its application to the problem.
There is some confusion regarding the application of the average velocity formula and the specific time intervals being referenced. Participants are questioning the setup and ensuring they are using the correct values for t and h in their calculations.
xCanx
I'm having trouble understanding this word problem.
A construction worker drops a bolt while woring on a high-rise building 320m above the ground. After t seconds, the bolt has fallen a distance of s metres, where
s(t) = 320-5t^2, o < t < 8
a. Find the average velocity during the first, third and eighth seconds.
I have to use f(x + h) - f(x)/h
I got 5(t +h)
The answer is 5m/s for the first one.
How do I get the rest of them (third and eighth second)?
the "first second" is from t= 0 to t=1, of course: average speed during the first second is s(1)- s(0) since here h= 1. The "third second" is between t= 2 and t= 3 so average speed during the third second is s(3)- s(2) and the "eighth" second is between t= 7 and t= 8 so average speed for the eighth second is s(9)- s(8).
Thank you :)
so I plug in h into 5(t+h)^2?
this is what I have so far
You are making the problem too difficult. Velocity is the change of position over time. The formula you list is the formula for position.
[tex]\frac{s(t+h)-s(t)}{h}[/tex] is the formula for average velocity.
It is a very wordy way of saying [tex]\frac{\Delta x}{\Delta y}[/tex],
which is the change in y over the change in x. (<--slope)
Now in order to see this, you know that [tex]\Delta y =y_{final}-y_{initial}[/tex] right? Can you see how that is the same as [tex]s(t+h)-s(t)[/tex] ?
It is saying: take the position of some initial time (t) PLUS some amount h and subtract the original initial time from it.
So in your second problem after 3 seconds, since your initial time is 0 and your final time is 3 then t+h means 0+3 which is of course 3.
You see h is the change in time from 0 to 3.
So now back to the problem; you should evaluate it as
[tex]v_{avg}=\frac{s(3+0)-s(o)}{3}[/tex]
  • · Replies 18 ·
