Stress in rotating ring segment
The discussion revolves around the analysis of radial and tangential stress in a segment of a rotating ring, particularly in the context of a chuck on a lathe and its bolted connections. Participants explore the theoretical underpinnings of stress distribution in rotating bodies and the implications for mechanical design, especially concerning failure modes in bolted joints under dynamic loading conditions.
  • One participant seeks the equations for radial and tangential stress in a segment of a rotating ring, noting that existing literature primarily addresses solid rings.
  • Another participant questions the nature of forces acting on the ring and clarifies the distinction between a solid ring and a segment, suggesting that the problem may involve dynamics and rigid body mechanics.
  • A participant provides equations for stress in a solid ring and emphasizes that the analysis for a segment may differ significantly due to the lack of symmetry.
  • Concerns are raised about the adequacy of bolt strength and the potential for failure modes, with one participant sharing a real-world incident involving bolt failure in a CNC machine.
  • Participants discuss the implications of simultaneous bolt failure and the need to consider factors such as load distribution, eccentricity, and proper installation of bolts.
  • There is a suggestion that the analysis should account for the clamping force on the wedges to reduce reliance on bolts as the primary shear load carriers.
  • One participant challenges the terminology used regarding the geometry of the ring segment, advocating for clarity in definitions.
Participants express differing views on the adequacy of existing stress equations for solid rings when applied to segments, and there is no consensus on the best approach to analyze the stresses and failure risks in the described scenario. Multiple competing perspectives on the mechanics involved and the implications for design remain unresolved.
Limitations include the potential for missing assumptions regarding load conditions, the dependence on specific definitions of ring geometry, and unresolved mathematical steps in the analysis of stress distribution in the segment.
Mechanical engineers, designers of rotating machinery, and students studying dynamics and stress analysis in mechanical systems may find this discussion relevant.
matthewbanar
Hi guys.
I was wondering if any of you happened to know the equation for the radial and tangential stress developed across a segment of a ring in rotation.
I have been looking through countless machine element design books, and all I can come across is one for a solid ring (like a flywheel). I am looking, moreover, for the stress developed at an element within a segment of a ring (like analyzing the chuck on a lathe) due to its inertia alone.
I was asked to do an analysis on the stress developed (and test it versus the shear strength of the bolts) of a sector of a cylinder bolted in two equally spaced locations.
Anyway. I bet this sounded horribly confusing.
-matt
It does sound horribly confusing!
If I understand the question correctly ("find the stress tensor within a hoop of large radius R and small radius r, R >> r, rotating about its symmetry axis with angular frequency [itex]\omega[/itex], and with given density and elastic constants"?), then oddly enough, this was the Newtonian background for a lengthy discussion in another PF forum, which led to this thread https://www.physicsforums.com/showthread.php?t=171079&page=3
Do any surface forces act on this ring? Body forces? Or should we think of an isolated ring far from any matter rotating about its symmetry axis? (]i]Segment[/i] of a ring? How would that rotate?)
By "solid ring" I presume you mean a "disk"? Like a pizza pie, rather than a wedding ring?
Well, somewhat.
I know how to find the magnitudal radial and tangential stress over a sold ring in rotation about its centroid already. That's given by:
[tex]\sigma_{r}=\rho\omega^{2}(\frac{3+v}{8})(r_{i}^{2}+r_{o}^{2}+\frac{r_{i}^{2}r_{o}^{2}}{r^{2}}-r^{2})[/tex]
[tex]\sigma_{t}=\rho\omega^{2}(\frac{3+v}{8})(r_{i}^{2}+r_{o}^{2}+\frac{r_{i}^{2}r_{o}^{2}}{r^{2}}-\frac{1+3v}{3+v}r^{2})[/tex]
where [tex]\rho[/tex] is the mass density of the ring/disk, [tex]\omega[/tex] is the angular velocity of the ring/disk, [tex]v[/tex] is the Poisson's ratio for the material, [tex]r_{i}[/tex] is the radius of the inner curvature, [tex]r_{o}[/tex] is the radius of the outer curvature, and [tex]r[/tex] is the radius of the element under consideration.
This approximation only holds if the outside radius of the ring, or disk, is large compared with the thickness (at least by a factor of 10), the thickness of the ring is constant, and the stresses are constant over the thickness.
["3-15 Stresses in Rotating Rings". Shigley's Mechanical Engineering Design, Eighth Edition. p.110]
That having been said, I need the analysis of only a segment of the ring, as I have crudely drawn and attached. Intuitively, I know that this stress is decidedly more than that of a ring.
Here, let me think of a ficticious example.
Let's say I have the world's most amazing Merry-Go-Round. It's built of a hyperalloy that cannot yield (even if I crank it up to 8000 rpm). I strip everything off it until it looks like a rotating, round platform of 15 feet in diameter. Now, let's say I have a chunk of mild steel that matches 30 degrees of the outer diameter of the Merry-Go-Round, but also has an concentric inner diameter of 12 feet. Let's also assume I bolt the 30-degree/15ft OD/12ft ID to the hyperalloy Merry-Go-Round such that it is concentric to it with four SAE Grade 1 Steel 1/2-13 bolts along a bolt circle of 13.5 feet.
How fast can I crank the Merry-Go-Round before the bolts fail due to shear?
If it was a solid ring bolted to the Merry-Go-Round, I could simply compare my radial stress and tangential stress to the shear strength of my bolt. However, it's not a solid ring. It's a ring segment. It has to be calculated differently, because a ring must actually yield to leave the platform due to symmetry, whereas this segment is only being held to the platform by bolts and not symmetry.
I hope that clarifies my predicament.
-matt
Isn't this going to be more along the lines of a dynamics/rigid body type of problem? Granted you will develop some stresses in the wedge part, but they should be negligible compared to the stresses around the bolt holes due to the shear load loading on the bolts.
You could also over come the bolt limitations by providing a proper clamping force on the wedges so that the bolts are not the primary shear load carriers.
Well, I'm analyzing a near-miss at work on a CNC machine. Six 10.5 lb wedges forming a circle around a part (i.e. each 60 degree segments and touching) flew off into the walls of the CNC machine after shearing through two 3/8-16 bolts (in each wedge) that were holding them in place. They were on a 15"RI 18"RO circle, and it was cranked to 800 rpm when the bolt failure occurred. Even at that circle and at 800 rpm, sae grade 1 3/8-16 bolts (located at about 16"R) should have definitely hold the wedges in place, unless they were not tightened down.
The only way I know how to approach it is approximating it is as a centrifugal acceleration problem:
[tex]F=mv^{2}/r=mrw^{2}[/tex]
[tex]F=(10.5/32.2)(16/12)(800*2\pi/60)^{2}[/tex]
which gives about 3050 lbs of force, distributed across two bolts.
From that force, I can calculate stress and compare the stress to the shear strength of the bolt.
Is this the wrong way to approach this?
-matt
So all the bolts failed and all the wedges flew off "simultaneously"? If so, think about what that implies. Either something caused them all to fail at the same time, or the first wedge failed and that failure took the others withi it (for example the 3000lb of unbalanced load after the first failure did something bad). It doesn't seem likely that all the bolts would fail independently at the same time, unless there was a gross overload.
Some things to think about:
Your load calc looks sensible, but was it the only source of the load? What was being machined at the time? Was it properly centered? If the bolts were not properly tightened, did the work go off center and the unbalanced radial loads then wiped out the bolts?
Have you run the machine at similar conditions before? What does the operating manual say?
Don't you mean an "thick" annulus of inner radius r_i and outer radisu r_o and thickness w?
In the limit of vanishing thickness, a washer forms an annulus. In the limit of vanishing small radius, a wedding ring (or inner tube or round torus) forms a circle.
Good points Aleph.
First thing I would say is to really get a handle on the entire situation if you can. If you are told simply to look at the stresses involved, then I would say that you have to look at the loading if the wedges were installed correctly. Verify that the very butter-like grade 1 bolts will really suffice. Honestly, I will always have issues with basic joints that rely on bolts for shear loading. The pretension on the bolts should always be enough to create enough of a clamp load to hold your joint together.
Like Aleph pointed out, if there was an eccentricity, that will definitely add to the mix.
  • · Replies 35 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 67 ·
17K
  • · Replies 49 ·
