What is the magnitude of the position vector at time t = 7.5 s?
  • Thread starter Thread starter chaotixmonjuish
    Magnitudes Vectors
The problem involves a particle moving in the x-y plane with constant acceleration, where the initial position, velocity, and acceleration vectors are provided. The objective is to determine the magnitude of the position vector at a specific time, t = 7.5 s.
  • Participants discuss the setup of equations to calculate the position vector, with one participant attempting to derive equations for both x and y components. Others suggest using a specific kinematic equation but express uncertainty about separating the components correctly. There is also a question regarding the interpretation of the acceleration vector and whether it involves unit vectors.
The discussion is ongoing, with participants exploring different interpretations of the problem and attempting to clarify the setup of the equations. Some guidance has been offered regarding the use of kinematic equations, but there is no explicit consensus on the correct approach or interpretation of the acceleration vector.
Participants express confusion about the separation of the x and y components and the nature of the acceleration vector, questioning whether it should be interpreted with respect to unit vectors. There is also mention of challenges faced in the context of the homework platform, lon capa.
chaotixmonjuish
A particle moves in the x-y plane with constant acceleration. At time t = 0 s, the position vector for the particle is d = 1.8 m x + 4.2 m y. The acceleration is given by the vector a = 1.5 m/s2 x + 6.2 m/s2 y. The velocity vector at time t = 0 s is v = 1.7 m/s x - 1.7 m/s y.
I tried setting up two equations:
F(x)=1.8+1.7x+1.5x^2
F(y)=4.2-1.7y+6.2x^2
This yielding something like 340. That answer didn't bode well with lon capa. I'm just not sure how to set up an equation to solve this.
Just use the equation
d = x0 + v0*t + (1/2)at^2
Use that in the horizontal direction... then in the vertical direction.
That's where my problem is. I'm not sure how to separate x and y.
I might be misunderstanding the problem... is this:
supposed to be:
[tex]\vec{a} = 1.5\vec{a_x} + 6.2\vec{a_y}[/tex] where [tex]\vec{a_x}[/tex] and [tex]\vec{a_y}[/tex] are unit vectors in the x and y directions?
I'm assuming they are just unit vectors... if they are supposed to be x and y, then acceleration isn't constant...
I myself don't even know. This is the joys of lon capa.
I'm guessing they are just unit vectors... in case you just divide the problem into two parts... first deal with horizontal displacement (ie x direction)
x0 = 1.8
v0 = 1.7
a = 1.5
hence x = 1.8 + 1.7t +(1/2)1.5t^2
calculate that for t=7.5... that gives x at 7.5
do the same thing in the y direction... that gives y at 7.5
Using the x and y you calculated... get the magnitude of the position vector using pythagorean theorem
11K
