Thread Closed
Vector problem
Share Thread Thread Tools
Sep11-07, 11:12 PM   #1
Vector problem
Each of the displacement vectors and shown in Figure P1.38 has a magnitude of 3.00 m. Find the following values graphically. Report all angles counterclockwise from the positive x axis.
Figure P1.38
(a) A+B=?
magnitude m
60°
(b) A - B=?
magnitude
m
(c) B-A=?
magnitude m
(d) A- 2B
magnitude m
2. Relevant equations
C=A+B C=B+A C= A+ (-B) maybe X= mcos(theta) Y=msin(theta)
3. The attempt at a solution
Ive been working on this problem for long time now, these vector properties are confusing, so far i manage to come up with some diffrent ways to get the resulant for part A but i dont know if im doing it right. first thing i try to connect A to B but extending the tail towards the head of B, then i mesuared the resultant, but got wrong answer. Same thing when I went from B to A, I dont know if connecting them right. I really need some one to shine some light on this one. When I do extend to B from A it turns out to be a Eqaultrail triangle, so the angle must be 60 deg where it meets.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Sep11-07, 11:51 PM   #2
Recognitions:
Homework Helper Homework Help
If you draw the 3rd side of the triangle formed by the two sides you've drawn on the picture... ie draw a vector from the head of B to the head of A, what vector is that?
Sep12-07, 05:26 PM   #3
turns out with the help of a niffty program, the resultant goes straight in the middle of the two vectors when you have A+B. This forms a pallrelagram with an angle of 60 deg at the end. I figure it out for myself, but I appreicate the response. I just stay with it for whole time, but sheer luck it started fitting together. I was able to answer all the parts.
Thread Closed
Thread Tools
Similar Threads for: Vector problem
Thread Forum Replies
A 3D vector problem Calculus 10
C++ vector<vector<int> > problem Programming & Comp Sci 4
Vector Problem Calculus & Beyond Homework 1
Vector Problem Precalculus Mathematics Homework 1
vector problem..help please! Introductory Physics Homework 2
