Continuously Compounded Interest and Diving.
  • Context: Undergrad
  • Thread starter Thread starter niyati
    Interest
The discussion focuses on the relationship between light intensity underwater and the mathematical principles of continuously compounded interest. The differential equation governing light intensity, dL/dx = -kL, is solved to find the depth at which light intensity falls below one-tenth of its surface value. By diving to 18 feet, the intensity halves, leading to the calculation of the decay constant k as ln(2)/18. The final equation for light intensity at depth x is L(x) = Ce^(-ln(2)x/18), allowing for the determination of maximum working depth without artificial light.
  • Understanding of differential equations, specifically dL/dx = -kL
  • Familiarity with the concept of continuously compounded interest, A = Ao(e^(rt))
  • Knowledge of logarithmic functions and their properties
  • Basic understanding of light intensity and its measurement underwater
  • Explore the derivation and applications of differential equations in physics
  • Study the principles of logarithmic functions and their applications in real-world scenarios
  • Learn about the practical implications of light intensity in underwater environments
  • Investigate further into the mathematical modeling of exponential decay processes
Mathematicians, physicists, divers, and anyone interested in the applications of differential equations and exponential decay in real-world scenarios.
niyati
The intensity L(x) of ligh X feet beneath the surface of the ocean satisfies the differential equation:
dL/dx = -kL
As a diver, you know from experience that diving to 18 ft in the Caribbean Sea cuts the intensity in half. You cannot work without artificial light when the intensity falls below one-tenth of the surface value. About how deep can you expect to work without artificial light? We are learning compound interest and whatnot. So, the equation we manipulate is:
A = Ao(e^(rt))
A is probably a tenth of (-kL), which is the original surface value of the ocea. I somehow should use the ratio of 18ft cutting the intensity in half, but I'm not sure how.
O_o
I was wondering what in the world "compound interest" had to do with "diving". I thought perhaps you had to take out a loan to pay for your diving equipment!
Yes, the "differential equation" dL/dx= -kL has solution L(x)= Ce-kx as you can see by differentiating that. That, of course, contains two unknow constants, C and k. If you've done "compound interest" problems that are similar, you probably know you can find C by looking at the "initial valule". Here, L(0)= Ce0= C and, since x is "depth", is the amount of light at the surface. You also know " diving to 18 ft in the Caribbean Sea cuts the intensity in half. " Okay, measuring x in feet, you now know that L(18)= Ce-18k= C/2. The C's cancel and you have e-18k= 1/2. You can solve that for k by taking logarithms: -18k= ln(1/2)= -ln(2) so k= ln(2)/18.
Now L(x)= Ce-ln(2)x/18. You are told "cannot work without artificial light when the intensity falls below one-tenth of the surface value. " That is, when L(x)= C/10.
Solve L(x)= Ce-ln(2)x/18= C/10 for x.
By the way, while e is convenient for derivatives, all exponentials are equivalent. From e-18k= 1/2, you can calculate that (e-k)18= 1/2 or e-k= (1/2)1/18. You could rewrite L(x)= Ce-kt as L(x)= C(1/2)t/18 instead.
Thank you!
:DDD
  • · Replies 21 ·
