Bigger wheels accelarate faster?
  • Context: High School
  • Thread starter Thread starter JacquesVosser
    Wheels
The discussion revolves around the impact of wheel size on the acceleration and top speed of a Ford Fiesta ST150. Participants explore the relationship between larger wheels, acceleration from a standstill, and overall vehicle performance, considering both theoretical and practical implications.
  • Some participants argue that larger wheels result in slower acceleration but higher top speed, contingent on the engine's power output.
  • Others suggest that smaller wheels may lead to faster acceleration, particularly if tire spin is not a factor, while potentially reducing top speed if the vehicle was previously optimized for it.
  • A participant notes that the weight of the wheels is generally irrelevant unless there is a significant difference in materials, emphasizing that changing wheel size alters the gear ratio.
  • Another participant raises a question about the specific performance difference when changing from 205/40/17" to 215/35/18" tires on a car with 118KW at the flywheel, drawing an analogy to bicycles regarding force and wheel size.
  • One participant mentions that a larger wheel is akin to a higher gear, suggesting it would ultimately allow for higher speeds but would require more time to accelerate.
  • Another point made is that if the transmission and wheel size are matched to provide the same torque to the ground, the wheel with a lower moment of inertia (typically the smaller one) will yield better acceleration.
  • Concerns are raised about the moment of inertia of the flywheel and the friction of the tires as potential limiting factors in performance.
Participants express differing views on the effects of larger versus smaller wheels on acceleration and top speed, indicating that the discussion remains unresolved with multiple competing perspectives.
There are assumptions regarding the matching of transmission and wheel size, as well as the impact of tire friction and moment of inertia, which are not fully explored or quantified in the discussion.
JacquesVosser
HI i live in South-Africa and a few of us guys have been fighting on a car club about something...
I say that if you get 2 of the same cars (Ford Fiesta ST150) which has a standard of 17" wheels. Now you keep the same wheel on the one car and on the other you change the wheel to a larger wheel (Same weight) the the standstil accelaration would be faster on the larger wheel.They say that a larger wheel makes the top end faster and the standing start slower?
So the question is: Does a bigger wheel make my car accelarate faster from standstill but be more slower on top end?
Hope to hear from you soon.
Jacques
You've stated it both ways in your posts.
A larger wheel will result in slower acceleration and higher top speed if the engine has enough power. If not, at least the top speeds in each gear but the last will be higher.
A smaller wheel will result in faster acceleration if tire spin doesn't become an issue, and top speed may be reduced if the car was properly geared for top speed before the wheel change.
And the weight of the wheels is largely irrelevant, unless there's a huge difference such as tungsten vs. magnesium rims. What matters is that changing the wheel size (and this means tire diameter, not the rims) alters the gear ratio. Without using the actual numbers, going from 28" to 30" tires would be equivalent to swapping your 4:56 gearset for 4:11 unit. Again, those are made-up numbers. By following the power train from engine to ground, you can figure out the actual ones.
WHat wil be the defference on a car that puts out 118KW at the flywheel? if you go from a Standard mag+Tyre 205/40/17" to (new mag) 215/35/18" ??
The reason why i thought it would be faster on lower speed is cause like i bicycle when you give an amount of force on a bigger wheel it moves easier and the distance is a bit more that it covers on the road?
Jacques
Bigger wheel is equivalent to a higher gear; go faster ultimately, but take more time accelerating. Think of the radius as a lever arm.
If the transmission and wheel size are matched to provide the same torque to the ground (to eliminate the complication Danger pointed out), the wheel with the lower moment of inertia (typically the smaller one) will provide better acceleration. Moment of inertia is resistance to rotational acceleration.
If the wheels and gear ratios aren't matched, you also have to consider the moment of inertia of the flywheel. Also, this is all moot if the limiting factor is the friction of the tires.
  • · Replies 35 ·
  • · Replies 69 ·
18K
66K
9K
  • · Replies 38 ·
