Initial Velocity of a kicked rock
The problem involves a soccer player kicking a rock horizontally off a 40.0-meter-high cliff and calculating the initial speed of the rock based on the time taken for the sound of the splash to reach the player, which is 3.00 seconds. The speed of sound in air is assumed to be 343 m/s.
  • Participants discuss the equations of motion and the relationship between distance, speed, and time. There is confusion regarding the interpretation of variables and the setup of the problem. Questions arise about how to find the distance the sound travels and the horizontal distance of the rock's fall.
Some participants are attempting to clarify the calculations and the relationships between the variables. There is a mix of correct and incorrect reasoning, with some guidance provided on how to approach finding the horizontal distance and the time of flight of the rock. Multiple interpretations of the problem are being explored.
Participants express uncertainty about the definitions of variables and the application of the equations provided. There is a focus on understanding the physical setup and the implications of the given data, such as the speed of sound and the time delay in hearing the splash.
Claymore
A soccer player kicks a rock horizontally off a 40.0-m-high cliff into a pool of water. If the player hears the sound of the splash 3.00s later, what was the initial speed given to the rock? Assume the speed of sound in air to be 343 m/s.
Well to start off I have a graph which I don't know how to put it in here. To get things started I am currently taking General Physics and it seems a bit confusing than I thought.
Teacher gave us this:
r= x= ro + Vox t
y= Yo + Voy t + (gt^2)/2
v= Vfx= Vox
Vfy= Voy + gt
Im not sure if there's more to this ^
To my understanding where r= displacement if I am correct, and v is velocity(speed)
it seems that i plug in numbers and calculate them but I am having problem understanding the letters what they represent so i can't get to my solution or explain that, that's my solution. It may sound confusing
Height= 40m
a=g=9.8 m/s^2
speed of sound= 342m/s
Time=3s
r = r0 + volt + (gt^2)/2
= 0 + 342 m/s *3.0s -4.9m/s^2 * 3.0s^2
= 984.9 m
so then I used:
x = x0 Voxt
984.9m = 0 + Vox * 3s
Vox= 328.3 m/s
and:
y= y0 + Voyt + (gt^2)/2
40m= 0 + Voy*3 + -4.9m/s^2 * 3.0s^2
Voy= -28m/s
and I am stuck :( any help on what/how to get intial Velocity. Thanks in advance
Im new to forums as well :P
I'm finding it difficult to follow your solution... First step... what is the distance between the place where the soccer ball fell and where the soccer player is... hint: use the speed of sound.
well that's the thing how would i find the distance? oh and by the way its a rock (ball) :P
lol, why is he kicking a rock? hint: they give the speed of sound... they give the time it takes to hear the sound... what distance does the sound travel?
so speed of sound x time = distance?
343m/s * 3s = 1029 m
correct me if I am wrong :(
That is correct. Now how do you think you can find the horizontal distance?
put it in Triangle :p
so 40m^2 Height x Hd^2 = 1029^2
Hd^2 = 1029^ + 1600
Hd= 32 m
correct?
No that's not correct. Remember that the hypotenuse of a right angled triangle is given by [itex]a^2 = b^2 + c^2[/itex]. That means you need to subtract the vertical height squared from the hypotenuse squared and square root it. Thats a horrible sentence so I'll write it in formula.
[tex]b = \sqrt{a^2 - c^2}[/tex]
Next in the problem you'll have to find the time of flight of the rock. How do you think you would find that?
  • · Replies 44 ·
