Einstein Notation: How to Go from 16 Terms to 4 Terms
The discussion revolves around the application of Einstein notation in the context of a variational calculus problem involving spacetime four-vectors and their variations. Participants are examining the transformation of an expression with 16 terms to one with only 4 terms, specifically focusing on the role of the metric tensor in this process.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the correctness of the original equation and discussing the implications of contracting terms with the metric tensor. There are attempts to clarify how the number of terms changes through summation and contraction.
The discussion is active, with participants exploring different interpretations of the metric tensor's role in the transformation of terms. Some guidance has been offered regarding the nature of contraction and summation, but there is no explicit consensus on the implications of off-diagonal elements in the metric tensor.
There are ongoing debates about the necessity of understanding covariant and contravariant vectors in relation to the metric tensor, as well as the assumptions about the metric's properties that affect the number of terms in the equations being discussed.
ehrenfest
I am a bit new to Einstein notation. Why is this true:
[tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau} = \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x _ {\nu}}{d \tau}[/tex]
How can you go from 16 terms on the LHS to just 4 terms on the RHS. If it is relevant this is a variational calculus problem and x^mu is the spacetime four-vector and delta is the variation and tau is some parametrization.
EDIT: this equation is wrong. see below
I think there's an error in the RHS . It should be
[tex]\frac{d\delta x^{\mu}}{d\tau}\frac{d\delta x_{\mu}}{d\tau}[/tex]
which means that the second derivative term from the LHS was contracted with the metric tensor [itex]\eta_{\mu\nu}[/itex].
Actually it should be [tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau} = \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x _ {\mu}}{d \tau}[/tex] .
There is only one delta on the RHS. I still do not see the equivalence.
Okay, i didn't see the second delta missing. But the explanation is the same. The second term got contracted with the metric tensor.
Sorry. Could you elaborate? What does it mean mathematically when the second term gets contracted with the metric tensor? Why does the metric tensor not contract the first term also?
In the LHS you have a double summation. It doesn't matter which one is done first, i.e. the metric tensor is contracted with either of the 2 other terms, it doesn't matter with whom first. I chose the one to the right.
I see. The only reason this works is because the Minkowski metric has no off-diagonal elements. Otherwise, when you can contract the second element but you lose the Minkowski metric but you still have 16 terms, right?
It's irrelevant wether the metric has only diagonal nonzero elements. It's not even important if the metric is symmetric or not. It's just a doubly contracted triple tensor product. If it hadn't been for the contraction, it would have resulted in an object (tensor or not) with 4 indices, 2 upstairs and 2 downstairs. Applying this double contraction one gets an object without any index. The # of terms in the double summation is 16.
No. It works by definition. [tex]x_{\mu}[/tex] (with a down index) is defined by [tex]x_{\mu} = \eta_{\mu \nu} x^{\nu}}[/tex] (with an implicit sum over nu) whether or not [tex]\eta_{\mu \nu}[/tex] has off-diagonal elements.
The metric tensor has the property of converting covariant to contravariant and vice versa depending on whether it is had subscript or superscript indices. It's not even necessary to understand what covariant and contravariant really mean because einstein notation can be memorized via a set of rules you simply always obey.
Mathematical Physics by Kusse is a great book which explains everything you need to know about einstein summation notation in Ch. 1, 2, and 14(tensor analysis in non-orthonomal systems)... then again, if you're taking G.R. I assume your textbook goes through the notation as well.
If the metric had off-diagonal elements how could you possibly go from the 16 terms of [tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau}[/tex] to the four terms of [tex]\frac{d \delta x ^ {\mu}}{d \tau} \frac{d x _ {\mu}}{d \tau}[/tex] ?
ehrenfest: you're not thinking clearly. 1+1=2, despite there being 2 terms on the left, but 1 on the right. Similarly, [tex]\sum_i \sum_j a_{ij} = \sum_i A_i[/tex] is a valid equation, despite there being different number of terms on the left and right. In fact, if we didn't change the number of terms, we wouldn't really have done any summation, would we?
If you think about it, it's simply the fact that a number may be written as the sum of two terms, three terms, four terms, etc. Like you can write 15=7+8 or 15 = 5+ 7 + 3. The two expressions are equal even though they involve different number of terms in the sum. This is really all there is to it!
[tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau} = <br /> \eta_{00} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{01} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {1}}{d \tau}<br /> +\eta_{02} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {2}}{d \tau}<br /> +\eta_{03} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {3}}{d \tau}<br /> +\eta_{10} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{11} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {1}}{d \tau}<br /> +\eta_{12} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {2}}{d \tau}<br /> +\eta_{13} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {3}}{d \tau}<br /> +\eta_{20} \frac{d \delta x ^ {2}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{21} \frac{d \delta x ^ {2}}{d \tau} \frac{d x ^ {1}}{d \tau}<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {2}}{d \tau} \frac{d x ^ {\nu}}{d \tau}<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {2}}{d \tau} \frac{d x ^ {\nu}}{d \tau<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {3}}{d \tau} \frac{d x ^ {\nu}}{d \tau}<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {3}}{d \tau} \frac{d x ^ {\nu}}{d \tau}<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {3}}{d \tau} \frac{d x ^ {\nu}}{d \tau}<br /> +\eta_{\mu \nu} \frac{d \delta x ^ {3}}{d \tau} \frac{d x ^ {\nu}}{d \tau}[/tex]
If the offdiagonal elements of the Minkwoski metric were not all zero, it seems pretty clear to me that you would have more than 4 terms on the RHS. Sorry, I do not see how adding numbers 2 =1+1 is the same as this. There is no rule really for adding these terms like that is there?
Of course there is... you just put brackets around things.
Have you really understood the meaning of [tex]x^\mu[/tex] and [tex]x_\mu[/tex]? Because it currently looks like you don't understand how they're related to each other.
I do understand the covariant and contravariant vectors. How do you put brackets around things? Can you please show me? I just do not see it sorry!
There is something wrong in your expression. You fix the values of [tex]\mu[/tex] in the differentials but you forgot to fix the corresponding value of mu in eta.
Most textbooks take multiple chapters to explain them -- I suggest Gravitation by Misner, Thorne and Wheeler as the ultimate physics book. But any textbook on differential geometry should cover it.
My attempt:
For any vector space V, you can get a dual vector space V*, by considering linear functions on V: [tex]f:V\rightarrow \mathbb{R} \in V^*[/tex] iff [tex]f(aX + bY) = af(X) + bf(Y)[/tex] where [tex]X,Y \in V[/tex]. The vector spaces turn out to have the same dimensions, and linear functions on V* are isomorphic to V (though not in a canonical way!) We can define multiplication between an element of V and an element of V* to simply be the application of the function to the vector.
However, there is not a canonical way to take an element of V and make it into an element of V*. This means that there is more than one possible isomorphism between the spaces, and none of them are preferred in anyway. We can define a way through a metric, [tex]g:V \rightarrow V*[/tex], combined with the multiplication we defined earlier, this allows us to define an inner product on V: [tex]\langle . | . \rangle : V \cross V \rightarrow \mathbb{R}[/tex].
Now, we can introduce a basis set on V, [tex]\mathbf{e}_\mu[/tex] (the superscript index does *not* denote a component!), such that a vector can be expressed as [tex]\mathbf{v} = v^\mu \mathbf{e}_\mu[/tex], where [tex]v^\mu[/tex] are the components of the vector. We can also introduce a basis in V* [tex]\mathbf{\theta}^\mu[/tex], such that [tex]\mathbf{\theta}^\mu \mathbf{e}_\nu = \delta^{\mu}_{\nu}[/tex]. Note that the up/down of indices are just convention -- reversing them would have no effect on the maths being done. Now, given a v in V and u in V*, we would multiply them as: [tex]\mathbf{uv} = u_\mu \mathbf{\theta}^\mu v^\nu \mathbf{e}_\nu = u_\mu v^\nu \delta_\nu^\mu = u_\mu v^\mu[/tex]. Because we only ever multiply elements from V to V*, the basis elements always drop out, and we usually never write them down explicitly. Now, our metric, g, is linear in its argument. As it happens, we can therefore express it as a series of numbers [tex]\mathbf{g} = g_{\mu\nu}\mathbf{\theta}^\mu\mathbf{\theta}^\nu[/tex], such that we can create V* vectors from V vectors by doing a summation: [tex]v_\mu = g_{\mu\nu}v^\nu[/tex]. Technically, it's a bit of abuse to call the covector and the vector both v -- in many textbooks they'd be differentiated as [tex]\bar{v}[/tex] and [tex]\tilde{v}[/tex].
In your given case, [tex]g = \eta[/tex]. As you can now see, it's pretty obvious why the contraction occurred.
Thank you for that explanation, but again, I know about covariant and contravariant vectors. Let's use a simple example:
So, why does
[tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau} = <br /> \eta_{00} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{01} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {1}}{d \tau}<br /> +\eta_{10} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{11} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {1}}{d \tau}[/tex]
[tex]= \eta_{00} \frac{d \delta x ^ {0}}{d \tau} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{11} \frac{d \delta x ^ {1}}{d \tau} \frac{d x ^ {1}}{d \tau}[/tex]
[tex]=\frac{d \delta x ^ {\mu}}{d \tau} \frac{d x _ {\mu}}{d \tau}[/tex]
The second equality simply makes no sense to me.
You claim that you understand them, but clearly you don't. All the equation is doing is "lowering an index", which is done by contracting with the metric. By *definition*
[tex]x_\mu = \eta_{\mu\nu}x_^\nu[/tex]
If you understand that, then what's the problem?
Note that the entries of [itex]\eta_{\mu\nu}[/itex] are just scalars, so
[tex]\eta_{\mu \nu} \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x ^ {\nu}}{d \tau} =<br /> \frac{d \delta x ^ {\mu}}{d \tau} \frac{d \left( \eta_{\mu \nu} x ^ {\nu} \right)}{d \tau}[/tex]
and since, as you know (and was pointed out multiple times here)
[tex]\eta_{\mu \nu} x^\nu = x_\mu[/tex],
this is equal to
[tex]\cdots = \frac{d \delta x ^ {\mu}}{d \tau} \frac{d x_{\mu}}{d \tau},[/tex]
and by summation convention there is a summation over [itex]\mu[/itex] (if you doubt this, write it out again with explicit summation symbols).
Period. There's nothing more to it.
So, why does
That should read
[tex]= \frac{d \delta x ^ {0}}{d \tau}\frac{d x _ {0}}{d \tau}<br /> + \frac{d \delta x ^ {1}}{d \tau}\frac{d x _ {1}}{d \tau}[/tex]
because
[tex]\eta_{00} \frac{d x ^ {0}}{d \tau}<br /> +\eta_{01} \frac{d x ^ {1}}{d \tau}[/tex]
[tex]= \frac{d x _ {0}}{d \tau}[/tex]
Do you mean 2 times that? And is that supposed to equal zero somehow?
No, and no. I get the feeling that the problem is not with the Einstein summation convention, but rather with the metric tensor and how it is used to raise and lower indices on other tensors.
[tex]\eta_{\mu \nu}A^{\nu}[/tex]
means
[tex]\Sigma_{\nu = 0}^{3}\eta_{\mu \nu}A^{\nu}[/tex]
Is that agreed? If not, then you do indeed have trouble with the convention. If so, then do you know that for a tensor A,
[tex]A_{\mu} = \eta_{\mu \nu}A^{\nu}[/tex]
If not, then you need to learn about the metric tensor. If so, then apply this formula in my previous message.
Agreed. Applying your formula, I get
[tex]= \frac{d x _ {0}}{d \tau}<br /> + \frac{d x _ {0}}{d \tau}[/tex]
which is two times what you posted.
Hmm. I see you really have yet to understand index mechanics.
[tex]x_\mu = \eta_{\mu\nu} x^\nu[/tex] does NOT mean that [tex]x_0 = \eta_{00}x^0[/tex].
Therefore, you've got twice the correct answer.
You have:
[tex]\eta_{\mu \nu}A^{\nu} = A_{\mu} + A_{\mu}[/tex]
This is not the same as what I had in my last post:
[tex]\eta_{\mu \nu}A^{\nu} = A_{\mu}[/tex]
To be more specific:
[tex]A_{\mu} = \eta_{\mu \nu}A^{\nu} = \Sigma_{\nu = 0}^{3}\eta_{\mu \nu}A^{\nu} = \eta_{\mu 0}A^{0} + \eta_{\mu 1}A^{1} + \eta_{\mu 2}A^{2} + \eta_{\mu 3}A^{3}[/tex]
I think genneth has hit upon your problem. You should sum over greek letters, not over numbers:
[tex]A_{\mu} \neq \eta_{\mu 0}A^0[/tex]
I see now. Thanks.
  • · Replies 0 ·
