Why velocity increases when radius decreases
  • Context: High School
  • Thread starter Thread starter vivinisaac
    Radius Velocity
Angular momentum is defined as the product of mass, angular velocity, and radius, represented mathematically as L = m * ω * r. When the radius decreases while keeping angular momentum constant, the angular velocity must increase to compensate, resulting in a higher velocity of the mass along its circular path. This relationship illustrates that a smaller radius necessitates a faster rate of rotation, confirming the conservation of angular momentum, which is measured in units such as gm-cm²/sec or erg-sec in the cgs system.
  • Understanding of angular momentum and its components
  • Familiarity with circular motion concepts
  • Knowledge of conservation laws in physics
  • Basic grasp of vector mathematics
  • Study the principles of angular momentum conservation in various systems
  • Explore the relationship between linear and angular velocity in circular motion
  • Investigate the mathematical derivation of angular momentum equations
  • Learn about real-world applications of angular momentum in engineering and physics
Students of physics, educators teaching mechanics, and professionals in engineering fields who require a solid understanding of angular momentum and its implications in rotational dynamics.
vivinisaac
pls explain what is angular momentum
and if possible explain why velocity increases when radius decreases (not mathematically)
Linear momentum is equal to speed x mass.
Angular momentum is basically the same, except the mass is traveling in a circular path, it's relative to the angular velocity (speed of rotation) x mass x radius. The speed of the mass is equal to the angular velocity x radius, and if mass and angular momentum are constant, than a decrease in radius requires an increase in angular velocity, while the speed of the mass remains constant (same speed in a smaller circler means a faster rate of rotation).
Also, angular momentum is a conserved quantity, having the units of gm-cm2/sec (or erg-sec) in the cgs system. Angular momentum is the cross product of a momentum vector and its radial vector, thus oriented perpendicular to both.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 16 ·
