Figuring out the solution of the following Integral
  • Thread starter Thread starter JasonPhysicist
    Integral
The discussion revolves around the integral I = sin(x)/sqrt{4sin(x)^2+cos(x)^2} dx. Participants express difficulty in finding a solution and explore various methods and substitutions, indicating a complex nature of the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss potential substitutions, such as tan(x/2) and u = cos(x), while questioning the effectiveness of these methods. Some suggest rewriting the integral in different forms to simplify it, and others express frustration over the complexity of the integral.
There is an ongoing exploration of different approaches, with some participants noting that the integral may not have a solution expressible in elementary functions. Guidance has been offered regarding rewriting terms and considering definite integrals, but no consensus has been reached on a clear path forward.
Some participants mention the absence of the integral in standard reference texts, raising questions about whether the problem is intended as an indefinite integral or if it may only yield nice solutions for specific limits.
JasonPhysicist
Hello,I'm having problems figuring out the solution of the following Integral.Any hints would be much appreciated!There it is:
I= sin(x)/sqrt{4sin(x)^2+cos(x)^2} dx
[tex]I=\int\frac{sin(x) dx}{\sqrt{4sin^2(x)+cos^2(x)}}[/tex]
O.O wow thats...a toughie, no substitution seems to work...you could try tan(x/2)=y but you'd get a polynomial of degree 4 on the square root...
It would be so much nicer if that 4 was gone...
ok you could try getting rid of those sin^2 x by using those formulas
[tex]sin^2 (x) = \frac{1-cos 2x}{2}[/tex]
[tex]cos^2 (x) = \frac{1+cos 2x}{2}[/tex]
that might lead you somewhere decent but you'll have some problems with sin(x) on the top but square root of acos2x + or - something...
Yeah,I've tried everything you've listed above,but had no success lol.
Anyway,thank you !
Not expressible in elementary functions or in a closed form.
There it is:
It's always a bad sign when it doesn't show up in Gradshteyn & Ryzhik...
Are you sure that you're asked for the indefinite integral? The closest entry I found was [3.676 #1] in G&R, 5th edition:
rewrite [tex]4sin^2(x)+cos^2(x)[/tex] as [tex]1+3sin^2(x)[/tex] and use
definite integral from 0 to pi/2 of [tex]\int\frac{sin(x) dx}{\sqrt{1+p^2sin^2(x)}}[/tex]
= (1/p) arctan p , with p^2 = 3 .
It looks like this may be one of those integrals that only has nice solutions for *certain* definite limits, but not in general...
so yea I tried it and my integral has complex numbers, so I'm going to go recheck my work.
[tex]I=\int\frac{sin(x) dx}{\sqrt{4sin^2(x)+cos^2(x)}}= \int\frac{sin(x)dx}{\sqrt{4- 5cos^2(x)}}[/tex]
Let u= cos(x) so du= sin(x)dx and the integral becomes
[tex]\int\frac{du}{\sqrt{4- 5u^2}}= \frac{1}{2}\int\frac{du}{\sqrt{1- \frac{5}{4}u^2}}[/tex]
Letting [itex]sin(\theta)= \sqrt{5}/2 u[/itex] should convert it to a rational integral.
Thats some really nice work there Halls! I wish i'd seen that =] Just One tiny mistake though, u=cos x so du = - sin x dx, so the actual integral is the one you gave, just with a negative sign stuck out the front.
I am likewise chagrined to have missed that; I was focusing on the sine-squared term, rather than the cosine-squared one.
One other little thing, though: 4 (sin x)^2 + (cos x)^2 =
4 [1 - (cos x)^2] + (cos x)^2 =
4 - 4 (cos x)^2 + (cos x)^ 2 =
4 - 3 (cos x)^2 , no?
+, - what does it really matter!:redface::cry:
Yeah, signs are *really* only important if you go to pick something up and the nuclei turn out to have negative charge...
  • · Replies 22 ·
  • · Replies 105 ·
13K
