How Do You Calculate the Mass of Mars Using Phobos' Orbit?
  • Thread starter Thread starter Saladsamurai
    Mars Mass
The discussion revolves around calculating the mass of Mars using the orbital characteristics of its moon, Phobos. The problem involves concepts from gravitational physics and orbital mechanics.
  • Participants discuss the relationship between gravitational force and centripetal force, exploring the equation involving mass, radius, and orbital period. There are attempts to derive the mass of Mars using the formula involving gravitational constant and orbital parameters.
Several participants have provided feedback on the original poster's approach, pointing out potential errors in the algebra and the need to reconsider the power of the radius in the final equation. There is an ongoing exploration of the correct formulation and calculations, with some participants expressing concern about their understanding of the method.
Participants are working under the constraints of homework guidelines, which may limit the extent of direct assistance. There is a shared focus on learning the method rather than simply obtaining the answer.
Saladsamurai
The Martian satellite Phobos travels in an approx circular orbit with r=9.4*10^6 meters and period 7h 39min. Find the mass of mars.
I am supposed to use the concept of gravitational F=centripetal force[tex]=m\frac{v^2}{r}[/tex] and the fact that [tex]v=\frac{2\pi r}{T}[/tex]
so this is my attempt:
[tex]F_g=\frac{GMm}{r^2}=m(\frac{v^2}{r})[/tex]
implies [tex]\frac{GMm}{r^2}=\frac{m4\pi^2r}{T^2}[/tex]
implies [tex]M=\frac{4\pi^2r}{GT^2}[/tex]
Should this not work? or am I just putting these numbers into my calculator wrong. I have T in seconds=275405
Text says it is 6.5*10^23 kg
Casey
ps I am more concerned with learning the method here.
You reasoning is fine just two small mistakes. Look at the radius in your final equation again and ask if it should be to that power, and calculate your time in seconds again.
You should have a factor r^3 on the RHS instead of r
Casey
should it be r^3 ...I am messing up my algebra here...wow...
T=7h 39 min= (7*3600)+(39*60)=27540...dont know where that last 5 came from! Thanks
Casey
Yes. Go to the previous step and ask yourself how you move the r2 term from the left to the right.
Sorry for butting in-- I was rather late! Glad you've got it though, Casey :smile:
Yeah, I'm a stooge. I treated the equals sign in this[tex]\frac{GMm}{r^2}=\frac{m4\pi^2r}{T^2}[/tex]
like it was a multiplication sign!
I love making up my own rules!
Casey
Feel free to butt in anytime:wink:
Yeah, I'm a stooge. I treated the equals sign in this [tex]\frac{GMm}{r^2}=\frac{m4\pi^2r}{T^2}[/tex]
Casey
No problem. We've all made that mistake and we all will again unfortunately. :smile:
If you solve your expression for T^2, you'll see that you've derived Kepler's Third Law for Mars, so you have that a check on your algebra. (I'm assuming you've seen Kepler's Law of Celestial Motion in your course by this point.)
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 17 ·
