3 dimension coordinate systems
The discussion revolves around understanding the representation of regions in three-dimensional space (R3) through inequalities and equations, specifically focusing on the inequality xyz=0 and the description of a bounded region in the first octant.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the implications of the equation xyz=0, questioning how to classify the resulting geometric shape and its relation to axes and planes. They also discuss the formulation of inequalities to describe a specific region in the first octant, raising questions about the bounds and interpretations of the inequalities.
Participants are actively engaging with the concepts, attempting to clarify their understanding of basic geometric representations in R3. Some guidance has been offered regarding the interpretation of equations and inequalities, but there is no explicit consensus on the classification of the regions or the formulation of the inequalities.
There are indications of confusion regarding the definitions and implications of the inequalities and equations, as well as the specific constraints of the homework problem. Participants are encouraged to slow down and reconsider basic concepts before proceeding further.
roadrunner
Describe in words the region of R3 (3 dimension) represented by the following inequality.
1)xyz=0
none i know of
no idea where to start. I know that this means one variable must be equal to 0, but i don't know how to classify it.
for example
x^2+y^2=r^2 is for a circle...
x^2+y^2+z^2=r^2 is a sphere
x^2 is a parabola
y=mx+b is a line
how would i clasify xyz... :)
NUMBER 2!
Write an inequality to describe the region.
a) region consisting of the firts octant bounded by z=1 y=2 z=3
what I've tried
i'm nt sure if this means x is bounded by x=0 and x=1...or if it means x<=1 and can continue infinatly (same with y and z)
and also, i think id have to make is such 6x=6 3y=6 2z=6 and make it in the form of x^2+y^2+z^2 >= 6 (or <=6 depending on the bounds)
thanks for some input ! :)
Can you describe the solution to x=0? To xy=0? Start simple, work your way up.
x=0 means there is only a y coordinate...so (0,y) and xy=0 means (0,y,z) or (x,0,z) or (0,0,z) so xyz=0 means that (x,y,0) or (x,0,z) or(0,y,z) or (x,0,0) or (0,y,0) or (0,0,z) or (0,0,0)
but how do i relate this to some sort of shape? or would i just use what i did?
Describe y=constant (or x=constant) in simple terms. Zero is just a special constant.
so z x and y and all constants...and at least one must be 0? that's how i would describe it?
and how about the 2nd question i had?
NUMBER 2!
what I've tried
Slow down, roadrunner. You are going too fast and in the wrong direction. You appeared to be having troubles with some very basic concepts, so I started simple. Let's start even simpler, with the equation x=c: What simple geometric shape does x=c represent in R1, R2, and R3? I'll give you a start: In R1 x=c represents a point.
Now specialize to the special constant zero. In R3, the three geometric shapes defined by three equations x=0, y=0, and z=0 have special names.
Finally, what does xyz=0 mean?
Problem 2. What simple expression defines the first octant (use the standard definition here)? This is a simple relation on (x,y,z). Now all you have to do is shift this so that the reference point is not the origin.
in R2 x=c means just a point also, and in R3?
quesiton two
X>=1 Y>=0 Z>=0 defins the firts octant. so would it be (x-1) +(y-2) + (y-3) >=0? that seems wrong, because that sitll doesn't show that x y and z have individual restrictions.
edit!
just noticed book said inequalities so can i just go x>=1 y>=2 z>=3
Not so fast, grasshopper. What simple geometric shape does y=mx+b represent in R2?
a line
but i thought you said just x=c?
did you mean in R2 use y=mx+b and in R3 use another formula that relates x z y?
Start with y=mx+b. Its a line in R2. Now set m to zero and change that 'b' to c. You get y=0*x+c, or simply y=c. This is still a line. Now change the 'c' to zero. By the way, this line (y=0) has a special name. x=my+b is also an equation of a line. Now set m to zero and b to zero. This (x=0) is still a line, and this line has a special name also.
To recap, in R1, the equation x=c represents a point, and in R2 it represents a line. What does this equation represent in R3?
parabola?
and the special name being the axis?
Stop guessing. How could it possibly be a parabola? A parabola "lives" in a plane, not in three dimensions. What is the next step in the progression a point, a line, a ... ?
Someone else needs to help roadrunner here, I am off 'til tomorrow morning.
circle?
i said parabola cause c=point x=line so i assume enxt was x^2 which is a parabola...but it would be a circle
ooo maybe at something? would xyz=0 refer to any point on an axis?
A very "relevant equation" is that if ab= 0 then either a= 0 or b= 0. If xyz= 0, then at least one of x, y, or z is 0. No, it is not "any point on an axis" because points on axes have two coordinates 0.
so then would it be any point on the plane xy, xz, yz ?
Bingo.
thanks man! haha
  • · Replies 27 ·
