Momentum & Velocity: Why Does Small Object End Up w/ 2w+v?
  • Context: Undergrad
  • Thread starter Thread starter bsmith2000
    Momentum Velocity
The discussion centers around the final velocity of a small object after colliding with a much larger object, specifically addressing the scenario where the small object is traveling at velocity v and the larger object at velocity w. Participants explore concepts related to momentum, energy conservation, and the differences between velocity and speed, while questioning the reasoning behind the final velocity being expressed as 2w + v.
  • Exploratory, Technical explanation, Debate/contested, Conceptual clarification
  • One participant questions the reasoning behind the final velocity being 2w + v, suggesting that the small object should bounce off with a relative velocity of -v, leading to a final velocity of w - v.
  • Another participant asserts that the change in velocity is 2v, not v, and encourages writing out the kinetic energies to understand the situation better.
  • Some participants clarify the distinction between velocity and speed, indicating that confusion may arise from mixing these concepts.
  • It is noted that for an elastic collision, the relative velocity of the small object before and after the collision is significant, and the velocity of the larger object does not change much due to its mass.
  • A participant presents a specific example involving a bullet and a pendulum block, indicating that the bullet's final velocity would be v1 + 2v2, raising questions about the calculations involved.
  • Another participant emphasizes that conservation of momentum and energy must be satisfied, suggesting that the larger mass must slow down if the smaller mass speeds up.
  • There is a discussion about transforming to a frame where the larger object is at rest, which simplifies the analysis of the collision.
  • Some participants express uncertainty about the terms used (speed vs. velocity) and how they affect the final expressions for the velocities.
Participants express differing views on the final velocity of the small object and the implications of conservation laws. There is no consensus on the correct interpretation of the velocities involved, and multiple competing views remain throughout the discussion.
Participants highlight the importance of distinguishing between speed and velocity, as well as the assumptions made regarding the masses of the objects involved. The discussion also reflects varying interpretations of the conservation principles in elastic collisions.
This discussion may be useful for students and enthusiasts of physics, particularly those interested in collision mechanics, conservation laws, and the nuances of velocity versus speed in elastic collisions.
bsmith2000
Why is it that when a small object traveling at velocity v, when colliding with a much larger object traveling at velocity w, ends up with a final velocity of 2w + v? What happens to the velocity of the large object?
I have seen the math behind this, but conceptually, I don't see how this works. I figured the small object would bounce off with a relative velocity of -v, thus making the actual velocity w-v. What is the flaw in this reasoning?
It has to do with conservation of energy. The velocity changes from +v to -v. So the change of velocity is 2v, not v.
Try writing out the kinetic energies of the objects before and after collision, and you'll see that it works out.
Are you sure about that? Possibly you are confusing velocity (a vector quantity) with speed (the magnitude of the velocity, so always >= 0).
Or you are confusing relative velocities and absolute velocities? (see below)
The relative velocity (relative to the large object) before the bounce is v-w, not v. For a very small object, and an elastic collision, the relative velocity afterwards is close to w-v and the velocity of the large object doesn't change much.
As compuchip said, for an elastic collision, write the equations for conservation of momentum and conservation of energy, and solve them. If you assume m1 << m2 for the two masses, you can get a simpler approximate solution.
well the first ball ends up with a velocity of 2w-v not 2w+v so if the velocity of the small ball is much larger than the larger ball it wud bounce back and the velcity of large ball will remain w
equation : final velocity of first ball=(m-M)v/m+M +2Mw/m+M
since M is much larger consider m=0
This is exactly how I thought it would be as well. However, I was doing a problem about a bullet traveling to the right at velocity v1 towards a block of wood attached to a pendulum. The pendulum was at the lowest point of the swing when the two elastically collided (so essentially, the block was traveling to the left at velocity v2). It asked what the speed of the bullet would be after the collision.
It said the bullet would end up with a velocity v1 + v2 relative to the block, so its actual speed would be v1 + 2v2.
This diagram also shows a similar idea: http://mysite.du.edu/~jcalvert/phys/assist1.gif
Well, how about showing the calculations that give that? The picture in that website can't be exactly correct. You show the larger object continuing with the same speed as before. That can't happpen. In order to have conservation of momentum and conservation of energy, the larger mass must slow down if the smaller speeds up.
The picture is correct (ok, not to infinite precision, but close enough to get the answer). One object is much bigger than the other: Imagine a ping pong ball colliding with a bowling ball. For all practical purposes, the speed of the bowling ball doesn't change. (Of course it must change a little to conserve momentum.)
Transforming to a frame in which the heavy object is at rest, as illustrated in the diagram, is the quick and easy way to solve this kind of problem. In that frame, the lighter object just bounces back with the same speed that it started. Then transform back to the original frame and you're done.
I don't understand - if its going at speed v -w and bounces back at speed v -w (relative to the big object at rest), where does the term v+ 2w come from (assuming the big object has speed w)?Edit: Hm, for some reason, I think the v + 2w answer comes up only when you use the word SPEED exclusively, and not velocity. So if the bullet at speed v hit the block going to the left at speed w, then the bullet would elastically bounce off at speed v + 2w. If everything was in terms of velocity, then it would be -v + 2w. Is this correct reasoning?
Let w & v stand for the speeds (magnitude only). Say the big object goes to the right at +w and the small object goes to the left, thus -v. The relative velocity before the collision is -v-w; after the collision, it's v+w (its sign is reversed). Thus the final velocity of the small object is w + v + w = v + 2w.
Ahhh Doc Al, thank you very much. I just edited my post right before you posted that, and you confirmed my prediction.
I appreciate everyone's help a lot. This problem has been bugging me so much. It's nice to have some closure. =)
So does this mean if w and v were velocities, and not speeds, the answer would be -v + 2w?
That's right.
  • · Replies 35 ·
  • · Replies 17 ·
