Does this make sense in set theory?
The discussion revolves around the definition and interpretation of the function image f(A) for a set A within the context of set theory. Participants explore the implications of defining f(A) based on the function f:X->Y and question the conditions under which this definition holds true.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the definition of f(A) and its relation to the elements of set A. There are questions about the bijectiveness of the function and the implications of using different set-building approaches, such as comprehension and replacement. Some participants express confusion over terminology and notation used in set theory.
The discussion is active, with various interpretations being explored regarding the definition of f(A) and the conditions under which it is valid. Some participants have offered clarifications and alternative perspectives on the definitions, while others express uncertainty about the terminology and concepts being discussed.
There is mention of confusion regarding the use of "replacement language" and "comprehension language" in set theory, indicating a potential gap in understanding among participants. Additionally, the discussion touches on the assumptions about the function f, particularly its injectiveness and surjectiveness.
pivoxa15
Let X be any set, f a function. Let f:X->Y
Does f(A) make sense for A in X?
I know f^(-1)(B) makes sense for B in Y.
I can't see why not
Yes, of course it does. f(A) is defined as {y| y= f(x) for some x in A}. In other words it is all values in y that you can actually "get to" using f.
f-1(B)= {x| f(x) is in B}.
Can you answer this: if f(x)= x2 and A= [-2, 1], what is f(A)?
Wouldn't you say for all x in A?
Since f is bijective, f(A)=[1,4]
You could do that, but why waste the words when there's no confusion?
And x^2 is *not* bijective. Think again...
No, I wouldn't! 4 is in f(A) for the example below because 4= f(-2). But it certainly is NOT true that 4= f(x) for ALL x in A!
Since f is clearly not bijective (it in neither injective nor surjective) that is not correct. To make one obvious point 0 is in [-2,1] so f(0)= 0 must be in f(A). It is NOT in [1, 4].
My bad, I should have drawn a graph. f(A)=[0,4]
With regards to 'f(A) is defined as {y| y= f(x) for some x in A}' What if I view y as a variable? So it is intepreted as all y in the codomain of f such that y=f(x) for all x in A.
It depends on how you're doing your set-building.
If we use comprehension, we are thinking about the elements of Y in the image of A.
[tex]f(A) = \{ \, y \in Y \mid \exists x \in A : f(x) = y \, \}[/tex]
If we use replacement, we are thinking about replacing every element of A with its image.
[tex]f(A) = \{ \, f(x) \mid x \in A \, \}[/tex]
in {y| y= f(x) for some x in A}, y is a member of a set, not a variable.
RIght. So I was thinking of 'replacement language' when intepreting HallsIvy's 'comprehension language' which obviously is not allowed hence the confusion.
What do you mean by "is not allowed"? :confused:
Adding y in replacement language
[tex]f(A) = \{ \, y=f(x) \mid x \in A \, \}[/tex]
and intepreting that y as the same y in comprehension language.
This certainly isn't grammatically correct. You have a free variable y, and the expression doesn't match any set-builder notation I know.
Anyways, it strikes me that I should have made a more positive response, and I'll do that now.
The axiom of comprehension (a.k.a. axiom of subsets) says that if you have some set S and some predicate P, there exists a set containing exactly those elements of S that satisfy P. A standard way to denote that set is with the syntax
[tex]\{ \, s \in S \mid P(s) \, \}.[/tex]
Sometimes, when S can be inferred from the context, you will see the shorthand notation
[tex]\{ \, s \mid P(s) \, \}.[/tex]
So, the expression
is certainly a grammatically correct mathematical statement.
Ouch! "Replacement Language"? "Comprehesion Language"? This is getting too deep for me. Whatever happened to good old set theory?
Left with Russell when he got his barber to shave him.
  • · Replies 24 ·
