What is Angular Momentum and How Do I Calculate It?
  • Thread starter Thread starter acerulz54
The discussion revolves around calculating angular momentum for a spinning coin, with specific focus on different reference points and the effects of linear motion. The subject area includes concepts of rotational dynamics and angular momentum in physics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the calculation of angular momentum for a spinning object, considering both its rotational and translational motion. Questions arise about the appropriate formulas to use for different parts of the problem and how to account for the motion of the center of mass.
Some participants have made progress on specific parts of the problem, while others are seeking clarification on the implications of the center of mass's motion and how it affects angular momentum calculations. There is an ongoing exploration of how to integrate linear momentum into the overall angular momentum.
Participants are discussing the implications of fixed versus moving reference points for calculating angular momentum, as well as the relevance of specific formulas in different scenarios. There is a mention of potential confusion regarding the angle in the context of linear motion.
acerulz54
Doc Al!--Blast from the Past
Hi Doc Al,
In 2004 you helped out a guy with this problem:
A 10 g coin of diameter 1.3 cm is spinning at 16 rev/s about a vertical diameter at a fixed point on a tabletop.
(a) What is the angular momentum of the coin about its center of mass?
(b) What is its angular momentum about a point on the table 10 cm from the coin?
(c) If the coin spins about a vertical diameter at 16 rev/s while its center of mass travels in a straight line across the tabletop at 5 cm/s, what is the angular momentum of the coin about a point on the line of motion?
(d) What is the angular momentum of the coin about a point 10 cm from the line of motion? (There are two answers to this question.)
You then responded:
This may help you: the angular momentum of an object is the sum of:
(1) the angular momentum of the center of mass
(2) the angular momentum about the center of mass
Thus:
a: See previous post
b: What's the movement of the center of mass?
c: See above
d: See above (there are two answers since you could be on either side of the line of motion)
2. I know I need 1/4 MR^squared for part a, but do I need 1/3 ML^squared for either b, c, or d?
3. I can handle part a, but but in part b I'm stuck: the center of mass is fixed there, but then in part c and d the cm travels in a straight line in the horizontal direction and I'm not sure how to take that into account. Can you help me? Thanks, and I'm glad a place like this exists for people like me!
acerulz54 said:
Hi Doc Al,
Hey, I was younger then!
What do you need 1/3 M L^2 for? (Not sure I understand where you got that.)
Read my response, which you quoted:
You then responded:
If the center of mass doesn't move, you can skip part (1).
If it does move, you have to add that additional angular momentum to the spinning part. What's the angular momentum of a moving point mass about some point? Hint: [tex]\vec{L} = \vec{r}\times\vec{p}[/tex], where p is the linear momentum of the mass. Read this: Angular Momentum of a Particle
Thanks for answering! OK, I got part (b). Now I think that if [tex]\vec{L} = \vec{r}\times\vec{p}[/tex] is worked out it becomes mvrsin[tex]\theta[/tex]. But if that's the case, the object is moving in a straight line. Doesn't that make [tex]\theta[/tex] zero? And if so, isn't L now zero as well?
The angular momentum contributed by the object's linear momentum depends on your reference point. If you compute the angular momentum about a point on the line of the object's motion, then theta is zero (or 180) and the linear momentum contributes nothing to the total angular momentum. (Read the link I gave in the last post.) But the spinning still contributes to the total angular momentum.
  • · Replies 71 ·
18K
