Theoretical Range Equation Derivation
The discussion focuses on deriving the theoretical range of a projectile, specifically a ball, using the variables y (vertical displacement), g (acceleration due to gravity), theta (launch angle), and v0 (initial velocity). The solution involves applying kinematic equations, particularly s = ut + 1/2 at^2 and v^2 = u^2 + 2as, to express time as a function of the initial vertical velocity component. The final step requires substituting this time into the horizontal motion equation to calculate the range accurately.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with trigonometric functions for angle calculations
  • Basic algebra for solving equations
  • Study the derivation of projectile motion equations in detail
  • Learn how to apply kinematic equations to different motion scenarios
  • Explore the effects of varying launch angles on projectile range
  • Investigate the role of air resistance in real-world projectile motion
Students studying physics, educators teaching projectile motion, and anyone interested in the mathematical modeling of motion in sports or engineering applications.
ccsmarty
Derive an expression for calculating the theoretical range of the ball in terms of y, g, theta, and v0.
I've tried just about everything to figure this out. I started with the motion in the x-direction, and plugged the second-to-last equation in for v0x in the second equation, and then solved for "t". Then I plugged the "t" into the second equation (but for the y-direction), and tried solving for "x". But I kept getting really weird numbers. Can someone please help me out?
Motion in the x direction is at a constant speed, so what you are looking for is the time given by motion in the y direction.
Use s = ut + 1/2 at^2 and v^2 = u^2 + 2as to get an equation for time as a function of initial vertical velocity component. Remember that final (vertical) velocity is zero at the top of the curve.
Then plug this into the horizontal component of velocity to get a range.
  • · Replies 21 ·
  • · Replies 32 ·
