2 Linear Algebra Proofs about Linear Independence
The discussion centers on two proofs regarding linear independence in linear algebra. Proof 1 establishes that a set of vectors S = {v1, v2, ... vp} is linearly independent if and only if the equation Ax = 0 has only the trivial solution, where A is formed by the vectors in S. Proof 2 confirms that if {v1, v2, ... vp} is a linearly independent set with p ≥ 2, then vp cannot be an element of Span {v1, v2, ... vp-1}. The participants emphasize the importance of understanding the definitions and implications of linear independence and spanning sets.
  • Understanding of linear independence and spanning sets in linear algebra
  • Familiarity with homogeneous systems of equations
  • Knowledge of vector spaces and their dimensions
  • Basic algebraic manipulation and proof techniques
  • Study the definition and properties of linear independence in detail
  • Learn about the rank-nullity theorem in linear algebra
  • Explore the concept of span and its implications for vector sets
  • Investigate the relationship between the dimension of a vector space and the solutions to homogeneous systems
Students and educators in mathematics, particularly those focusing on linear algebra, as well as anyone seeking to deepen their understanding of vector spaces and linear independence proofs.
alec_tronn
Proof 1:
Show that S= {v1, v2, ... vp} is a linearly independent set iff Ax = 0 has only the trivial solution, where the columns of A are composed of the vectors in S. Be sure to state the relationship of the vector x to the vectors in S
2. The attempt at a solution
As far as I can tell (from my book and class), the actual definition of linear independence is
"A set of vectors is linearly independent iff there exists only the trivial solution to c1v1 + c2v2+ ... + cpvp = 0, or similarly only a trivial solution exists to the equation Ax = 0 when the columns of A are composed of the vectors in S. "
I know many implications of this property, but not the steps in between the term and the definition. Is there a more basic definition that I need to start this proof out with? Are the two options I gave in my definition of linear independence really different enough to merit in-between steps?
Proof 2:
Prove or disprove: If {v1, v2, ... vp}, p>=2 is a linearly independent set, then vp is not an element of Span {v1, v2, ... vp-1}. 2. The attempt at a solution
I just took a guess at this one:
Assume that vp}, p>=2 is linearly independent, and let vp be an element of Span {v1, v2, ... vp-1}.
By definition of spanning, vp is a linear combination of {v1, v2, ... vp-1} .
By definition of linear combination, there exists c1v1 + c2v2+ ... + cpvp-1 = vp.
Algebra give us:
c1v1 + c2v2+ ... + cpvp-1 - vp = 0.
This gives a solution other than the trivial solution (where {c1, c2, ... cp} are all zero) to the equation c1v1 + c2v2+ ... + cpvp = 0, because cp must equal -1.
This is a contradiction. {v1, v2, ... vp}, p>=2 can't be a linearly independent set while vp is an element of Span {v1, v2, ... vp-1}. , so if {v1, v2, ... vp}, p>=2 is a linearly independent set, then vp is not an element of Span {v1, v2, ... vp-1}, as desired. Q.E.D.Any help or hints on either of these would be greatly appreciated. The first one I just need a starting point, and the second one I need to know if I made any mistakes, or if that is a valid proof. Thanks a lot.
I agree with the 2nd proof. In the first problem, the statement and the predicate (the definition) seem to be identical -- I am not clear on what is being asked.
Regarding proof 1, do you know anything about the dimension of the vector space of solutions to a homogenous system? How does it relate to the rank of the system matrix A? What *is* the rank of your matrix A, since it consists of p linear independent vectors?
  • · Replies 30 ·
