What Are the Limits to Quasi-CW in Non-Linear Optics?
  • Thread starter Thread starter n0_3sc
    Limits
The discussion centers on the limits of treating pulsed laser outputs as Continuous Wave (CW) signals in Non-Linear Optics. Specifically, it addresses the conditions under which square pulse trains can be approximated as Quasi-CW signals, particularly in the context of a laser ring-cavity oscillator designed for 1 ns pulses at a 1 MHz repetition rate. The consensus is that if the average power over a long time scale is the primary concern, any frequency significantly higher than the inverse of this time scale can be considered Quasi-CW. The design of the oscillator's fiber length is crucial for achieving the desired peak power without focusing on average power.
  • Understanding of Non-Linear Optics principles
  • Familiarity with laser technologies, specifically fiber lasers
  • Knowledge of pulse duration and repetition rate concepts
  • Basic grasp of Continuous Wave (CW) and Quasi-CW laser classifications
  • Research the effects of pulse duration on peak power in fiber lasers
  • Explore the design principles of laser ring-cavity oscillators
  • Study the implications of average power versus peak power in Non-Linear Optics
  • Investigate the relationship between pulse repetition rates and Quasi-CW behavior
Researchers and engineers in the field of Non-Linear Optics, laser physicists, and anyone involved in the design and application of pulsed laser systems.
n0_3sc
Could someone please explain what the limits to Quasi-CW is?
ie. If I have a train of square pulses, to what limit can I make the approximation that it can be treated as a Continuous Wave signal?
If that question was too vague here is my situation:
In Non Linear Optics you need lots of "watts" of power, now a 50W CW laser is impractical due to many reasons...so we use pulses...the shorter the pulse the higher the peak power.
However, most of Non Linear Optics theory relies on the fact that we are using CW lasers, but how short can you make a pulse until its no longer considered CW??
I think it depends on the specific question you're asking about the effects of the laser. If you care about average power over a long time scale and don't care about the frequency with which the energy is delivered, then any frequency significantly higher than the inverse of this time scale is "Quasi-CW". What, specifically, is the question?
The basic idea is I am doing a project involving a laser ring-cavity oscillator (more specifically a parametric oscillator), now because its made from only optical fibers the length of this oscillator is designed such that it is the length of a 1ns pulse at a repetition of 1Mhz. The average power is NOT important at all, we are concerned about peak powers.
So would it be correct by saying that it really doesn't matter on the repetition rate so long as this oscillators fiber length is adjusted to the right amount?
42K
  • · Replies 45 ·
13K
