Designing a Small Location Detection System with RFID Tags
The discussion revolves around designing a small location detection system using RFID tags or resonance techniques within a room. Participants explore the feasibility, challenges, and potential methods for accurately determining the position of objects equipped with unique identification codes.
  • One participant, benzun, seeks suggestions for a location detection system using RFID tags and proposes using four detectors to determine object positions.
  • Another participant points out that RFID tags typically have a short reading range, suggesting that longer distances require more power and directional antennas, along with advanced detection methods like phased array receivers.
  • Some participants mention that certain RFID tags can have ranges greater than 10 feet, indicating variability in tag capabilities.
  • A later reply highlights the complexity of the problem, mentioning multipath effects and suggesting alternative methods such as video location and triangulation, while questioning constraints like the need for passive tags and frequency bands.
  • One participant refers to a previous post that discusses a potential solution to multipath issues, noting that it may not be simple or inexpensive.
Participants express differing views on the capabilities and limitations of RFID technology for location detection, with no consensus on the best approach or solution to the challenges presented.
Participants mention various constraints and factors that could affect the design, such as the need for passive tags, frequency bands, and potential interference sources, but these remain unresolved.
benzun_1999
hi,
i need help... i am planing to design a small location detection system within a room using RFID tags or some resonace technique. Each object must have a unique identification code. I intend to place 4 detectors like Satellites to determine the exact position of the object... I need suggestions and ideas... please help me.
-benzun
RFID tags have a very short reading range ( typically a few cm)
You can read them at longer distances with more power and a more directional antenae.
You would also need more than just a simple RFID detector to give a good direction of the signal you would have to either scan the detectors to locate the maximum signal direction or have some sort of phased array receiver.
The timing of the rfid reply isn't repeatable enough to do a time-of-flight position fix.
I'm doing a little research into RFID tags myself and many of them have ranges greater than 10 feet. If you make any progress on determining accurate location, please post it. Here are some here are some RFID tags that I found.
benzun_1999 said:
hi,
-benzun
That is a very non-trivial problem, especially when you factor in multipath effects. Are there any other options like video location and triangulation, etc.? What other constraints are there in this project? Do the tags have to be passive (or at least not self-powered)? What frequency bands were you considering using? What interfering sources are you going to have to contend with?
Hey benzun, check out the end of my post #5 in this thread that cnichols is referring to:
https://www.physicsforums.com/showthread.php?t=187360
At first I didn't think there was a way to do this effectively, but the end of my post has an interesting possibility that pretty much gets around multipath issues, at least to a first order. It's not simple or cheap, though.
  • · Replies 0 ·
