Linear algebra area with vectors
The discussion centers on the calculation of the area vectors of a tetrahedron defined by vectors a, b, and c in R^3. It is established that the area vector of each face is perpendicular to the face and has a magnitude equal to the area. The correct approach involves using the cross product to determine these area vectors, specifically: bottom face as c × b, front face as b × a, back face as a × c, and right face as (b - c) × (b - a). The sum of these area vectors equals the zero vector, confirming the geometric property of the tetrahedron.
  • Understanding of vector operations in R^3
  • Knowledge of the cross product and its properties
  • Familiarity with geometric interpretations of vectors
  • Basic concepts of tetrahedrons and their properties
  • Study the properties of the cross product in vector calculus
  • Explore geometric interpretations of area vectors in three-dimensional space
  • Learn about tetrahedron properties and their applications in geometry
  • Investigate the implications of vector summation in physics and engineering contexts
Students and professionals in mathematics, physics, and engineering who are working with vector calculus, particularly in three-dimensional geometry and applications involving tetrahedrons.
braindead101
The figure below shows the tetrahedron determined by a,b,c E R^3. The area vector of a face is a vector perpendicular to the face, pointing outward, whose magnitude is the area of the face. Show that the sum of the four outward pointing area vectors of the faces equals the zero vector. I have attached the image.
Since the area of each face is identical can I just say it is some variable say c. So i am trying to look for the directional vector of each side.. but i am having trouble doing this. I think that vec b is one and vec (b-c) is another, but i am having trouble picturing the other two vectors especially the one pointing downwards.
Is this even the right approach to this problem?
Are you told that the area of each face is identical? That is NOT true for a general tetrahedron. (And, even if they were, it would be really bad idea to use the same symbol, c, for the area as for one of the vectors!)
Do you know the "cross product"? In particular, do you know that the area of a parallelogram having vectors [itex]\vec{a}[/itex] and [itex]\vec{b}[/itex] as adjacent sides is [itex]|\vec{a}\times\vec{b}|[/itex]? If you know that then the vectors referred to are just the cross products of two vectors each. Using the notation and order of edges that you have in your picture, the outward 'area vectors' are:
bottom face: [itex]\vec{c}\times\vec{b}[/itex]
front face: [itex]\vec{b}\times\vec{a}[/itex]
back face: [itex]\vec{a}\times\vec{c}[/itex]
right face: [itex](\vec{b}-\vec{c})\times\(\vec{b}-\vec{a})[/itex]
Using the distributive law and the fact that the cross product is anti-commutative will give you the result.
If you can't use the cross product- sorry!
hi I'm just wondering why for the right face it's b-c x b-a and not b-a x c-a
  • · Replies 17 ·
11K
