Magnetic Fields: Measuring Magnetic Field in a Point Inside a Volume
This discussion focuses on measuring the magnetic field at a specific point inside a volume influenced by multiple magnetic sources. The user expresses frustration with calculating the magnetic field of a single permanent magnet, emphasizing that understanding the field of one magnet allows for the summation of fields from multiple sources. The conversation references the concept of approximating a permanent magnet as a solenoid, utilizing parameters such as remnant field (B), length (l), section (s), and permeability (μ) to derive reluctance (R) and equivalent current (I). The challenges of analytically computing forces between permanent magnets are highlighted, noting the reliance on finite element analysis for viable solutions.
  • Understanding of magnetic field theory and concepts
  • Familiarity with solenoid equivalence in magnetism
  • Knowledge of reluctance and its calculation
  • Experience with finite element analysis (FEA) for magnetic fields
  • Research the principles of magnetic field superposition
  • Learn about the mathematical modeling of magnetic fields using finite element methods
  • Explore the derivation and application of reluctance in magnetic circuits
  • Study the behavior of magnetic fields in complex geometries
Physicists, electrical engineers, and researchers involved in magnetism, particularly those working on magnetic field measurements and simulations in complex systems.
Pris
I have a cluster of magnetic sources around a volume and I need to know the real magnetic field in a point (namely x_0) inside the volume by measurements in another point x' in the surface of the volume.
I'm getting mad
hehe,
I'm getting mad about computing the magnetic field of only 1 permanent magnet.
I guess that basically, if you know the field of 1, you will know the total field (summing).
Here is a wikipedia link, in which an approximation is made, to consider 1 magnet as a solenoid. http://fr.wikipedia.org/wiki/Réluctance
Unfortunately i did not find any equivalent in English.
It says :
A permanent magnet with remnant field B, length l, section s, [tex]\mu[/tex] its permability, it is equivalenent to a soleoind :
- of reluctance R = l/([tex]\mu[/tex]s)
- with : N.I = (l.B)/[tex]\mu[/tex], N the equivalent number of current loops, I the equivalent current
- length l and section s.
Imagine how is it frustrating when you need to analytically compute the force between two permanent magnets (actually, there is no viable direct computations, only based on finite element decompositions).
Correct me if I'm wrong.
http://ghazi.bousselmi.googlepages.c...3%A9sentation2
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 42 ·
  • · Replies 22 ·
