What Is the Form of G When k Is Complex?
  • Thread starter Thread starter madeinmsia
    Complex Root
The discussion focuses on the form of the function G when the constant k is complex in the ordinary differential equation G'' = -kG. It establishes that for k > 0, the solution takes the form G = Acos(sqrt(k)x) + Bsin(sqrt(k)x). When k is a complex number, the roots are expressed as r = +/- sqrt(-ki), leading to a different representation of G. The implications of complex k on the solution's form are crucial for understanding the behavior of the system described by the ODE.
  • Understanding of ordinary differential equations (ODEs)
  • Knowledge of complex numbers and their properties
  • Familiarity with trigonometric functions and their applications in ODE solutions
  • Basic skills in mathematical analysis and root calculations
  • Study the properties of complex square roots in depth
  • Learn about the applications of complex numbers in differential equations
  • Explore the method of undetermined coefficients for solving ODEs
  • Investigate the implications of complex roots on the stability of solutions
Mathematicians, physics students, and engineers who are working with ordinary differential equations and require a deeper understanding of complex constants in their solutions.
madeinmsia
G'' = -kG
k is a constant
solving this ODE, r = +/- sqrt(-k)
if k > 0, then r = +/- sqrt(k)i
so G is in the form Acos(sqrt(k)x) + Bsin(sqrt(k)x)
so, what if k is a complex number, then
r = +/- sqrt(-ki)
then what is the form of G?
r = +/- sqrt(-ki)
Don't you know how to calculate http://www.mathpropress.com/stan/bibliography/complexSquareRoot.pdf?
  • · Replies 22 ·
