Solving a Homework Problem: Finding the Limit to x-->1+
  • Thread starter Thread starter Wonderballs
The discussion revolves around finding the limit of the expression |x-1|/(x^3-1) as x approaches 1 from the right. The problem is situated within the context of limits and polynomial factorization.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the factorization of the polynomial x^3-1 and question how it can be expressed as (x-1)(x^2+x+1). There are attempts to verify this factorization through multiplication and polynomial division. Some participants express confusion about the steps involved in reaching this factorization.
Several participants have provided insights into the factorization process and shared relevant equations related to polynomials. There is an ongoing exploration of different methods to understand the factorization, with some participants offering to assist further if needed. The discussion reflects a mix of interpretations and attempts to clarify the mathematical reasoning behind the problem.
Participants mention the challenge of factoring polynomials and the lack of familiarity with specific equations related to cubic expressions. There is also a reference to imposed homework rules and the context of a practice test, which may influence the discussion.
Wonderballs
lim |x-1|/x^3-1
x-->1+
This is from a "practise test" and the prof wrote his solution on it... I'm having a hard time figuring out why (x^3-1) = (x-1)(x^2+x+1) which is what he used to find the limit... I am fine at figureing out limits but I just have no idea how he figures those two equations are equal because when i multiply through i get (x^3-2x^2+2x-1)
(x-1)(x^2+x+1)=x^3+x^2+x-x^2-x-1=x^3-1 where the first three terms are obtained by multiplying the first term in the first bracket through with the right bracket, and the last three terms are obtained by multiplying the second term in the first bracket through with the right bracket.
You're professor is right. Try multiplying it out again. If you get the same (wrong) answer again, show your work, and we'll help show you how to get to the correct answer.
Edit:
Well forget that. Cristo just did it for you.
Lol, thank you on my paper i have it written down as (x-1)(x^2-x+1)...
But I am still wondering how you get from (x^3-1) TO (x-1)(x^2+x+1)
I have tried to factor by grouping but that got me nowhere...
I don't remember that equation specifically. I do remember that
[tex]x^n-1 = (x-1)(x^{n-1}+x^{n-2}+\cdots+x+1)[/itex]<br /> Equations of this form come up a lot. It is worth knowing.<br /> <br /> If not, you have to factor. In general, yech. There is a general rule for solving cubics. I use it so infrequently I have to look it up every time I use it. There is a general rule for solving quartics, which I never use. There is no general rule for higher order polynomials. On the other hand, I run into things like [itex]1/(1+x)[/itex], [itex]1/(x-1)[/itex], and [itex](x^n-1)/(x-1)[/itex] all the time.[/tex]
(x^3-1)=(x^3+x^2-x^2+x-x-1)
=(x^3+x^2-x^2)+(+x-x-1)
=-1(-x^3-x^2+x^2)-1(-x+x)
=-1(i don't know...
You can spot that x-1 is a factor and then use polynomial division. I don't think I've ever used the cubic formula!
is it called the binomial theorem?
There is a fairly well known equation for difference of cubes:
[tex](a^3-b^3)=(a-b)(a^2+ab+b^2)[/tex]
It's fairly easy to prove, once you just multiply everything out. There is also an analogue for addition of cubes which I do not provide for the reader.
  • · Replies 22 ·
