Find the Height of Ball and Stone at Intersection | Vertical Freefall Problem
  • Thread starter Thread starter AraProdieur
    Ball Freefall
The discussion focuses on calculating the height at which a ball and a stone intersect during their vertical motion. The ball is thrown upward at 15 m/s, and the stone is thrown 0.92 seconds later at 27 m/s, both under the influence of gravity (9.8 m/s²). The equation derived for their heights is 15(t + 0.92) - 4.9(t + 0.92)² = 27t - 4.9t². The time of intersection is calculated as t = 0.4593 seconds after the stone is thrown, and the correct height can be determined by substituting this time back into one of the height equations.
  • Understanding of kinematic equations for vertical motion
  • Familiarity with quadratic equations and their roots
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Basic algebra skills for simplifying equations
  • Study kinematic equations for vertical motion in detail
  • Learn how to solve quadratic equations and identify correct roots
  • Explore the concept of relative motion in physics
  • Practice problems involving multiple objects in freefall
Students studying physics, educators teaching kinematics, and anyone interested in solving vertical motion problems involving multiple objects.
AraProdieur
A ball is thrown vertically upward with an initial speed of 15 m/s. Then, 0.92 s later, a stone is thrown straight up ( from the same initial height as the ball) with an initial speed of 27 m/s. The acceleration of gravity is 9.8 m/s^2.
How far above the release point will the ball and stone pass each other? Answer in units of m.
So far, I have written down this equation 15( t + 0.92) - 4.9(t + 0.92)^2= 27t- 4.9t^2
And when I simplify everything, I get a t= .4593
Now, I don't know if that is even remotely correct, but if I am, I would like to know how to go about getting closer to the answer at hand.
Thank you.
EDIT: oops sorry... for some reason I thought the second ball was being thrown down from above. Thanks Astronuc.
Your solution is correct for finding time, t, which according to your approach is the time after release of the stone. The ball is leading by 0.92 s.
So one has set the height equal and then one solves for the time.
Then pick one of the height equations and solve for the height as a function of the t.
Since one has a quadratic, make sure to pick the correct root.
  • · Replies 38 ·
10K
  • · Replies 19 ·
