Can a Set be Well-Ordered Without the Axiom of Choice?
The discussion revolves around the implications of well-ordering in set theory, specifically examining the conditions under which a set can be well-ordered without the Axiom of Choice. Participants explore the relationship between total orders and well-orders, and the implications of these properties on the cardinality of sets.
  • Participants discuss the implications of assuming every total order on a set is a well-order, questioning the existence of bijections between the set and its union with itself. There are inquiries about examples of total orders that are not well-orders and the conditions under which these properties hold.
The discussion is active, with participants sharing insights and raising questions about the relationship between total orders and well-orders. Some participants suggest that the conditions may imply finiteness of the set, while others express uncertainty about the implications of rejecting the Axiom of Choice.
Participants note constraints such as the inability to assume the Axiom of Infinity and the implications of not having the Axiom of Choice, which influence the exploration of the problem. There is also mention of a larger question involving the equivalence of multiple statements related to set theory.
Dragonfall
Show that if every total order of a set x is a well-order, then there is no bijection between x and [tex]x\cup\{ x\}[/tex] = Sx.
Suppose there was, then you can have a total order on x and an induced total order on Sx. But this induced order on Sx is a total order on x. Something bad's supposed to happen here.
Anyone?
Do you know of any examples of total orders that are not well-orders?
Yes, the usual order on the real numbers.
Okay, so you've proven that if every total order of a set x is a well-order, then x does not have the same cardinality as R. (right?)
We can't assume the axiom of infinity on this question (nor do we need to, apparently), so we can't assume that R exists, or even N, for that matter.
Basically the two conditions are equivalent to the fact that the set x is "finite". This question is actually part of a bigger question asking me to prove the equivalence of 6 statements, and this is the link in the chain that I can't prove.
I am certain I'm on the right track with the two total orders there, but I can't see a contradiction.
Here's the whole question. Prove the following are equivalent:
(a) Every injective function from x to x is surjective.
(b) There is no proper subset y of x in bijection with x.
(c) Every surjective function from x to x is injective.
(d) There is no proper superset y containing x in bijection with x.
(e) Every total order of x is a well order.
(f) There is no bjection between x and Sx = xU{x}.
This was my idea. Certainly, the thing you're trying to prove is an immediate consequence of this assertion.
The word "finite" and the phrase "well-order" suggest that induction might be useful.
By the way, is it obvious that every set has a total ordering?
Every set is in bijection with some cardinal. Every cardinal is an ordinal (under some models). Every ordinal is totally ordered by [tex]\in[/tex], so every set has a total ordering.
Whoops, I forgot to say 'without the axiom of choice'.
I was pondering the idea of trying to construct a counterexample; because condition (e) says "Every total order...", and you were assuming one existed, that prompted me to think about the case of a set x without any total orderings. Then, one of two things happen:
(1) The statement you are trying to prove is false.
(2) The set x is not bijective with Sx.
And so, I was mulling the possibility of having an infinite set x that is not bijective with Sx. Clearly this cannot happen if we assume axiom of choice, but I am not so familiar with the case where we reject the AoC, and I'm wondering if this is possible!
I don't think cardinality can be used as an argument, since Q is the same cardinality as N, but is not well-ordered.
I'm not familiar with set theory enough to say what you can't do without the axiom of choice. AC seems pretty intuitive to me.
I do have a side question: if the class of all things is in bijection with the class of all ordinals, then you can order the class of all things. What's wrong here?
