Measures of Central Tendency & t-86
  • Thread starter Thread starter kuahji
The discussion focuses on calculating measures of central tendency using the TI-86 calculator in conjunction with frequency distributions. The user successfully computed the mean (32.83) and standard deviation (11.06) by hand and seeks to replicate these results on the TI-86. To achieve this, the user must enter the class midpoints into the xstat and the corresponding frequencies into the fstat. This method ensures accurate computation of the mean and variance directly from the calculator.
  • Understanding of frequency distributions
  • Familiarity with the TI-86 calculator
  • Knowledge of statistical measures such as mean and standard deviation
  • Ability to calculate midpoints for class intervals
  • Learn how to input data into the TI-86 for statistical analysis
  • Explore the use of 1-Var Stats on the TI-86 for various datasets
  • Study the calculation of midpoints for grouped data
  • Investigate the differences between xstat and fstat on the TI-86
Students in statistics courses, educators teaching statistical methods, and anyone using the TI-86 calculator for statistical analysis.
kuahji
The statistics course I'm taking is a technology based course, & goes hand in hand with the ti-83. I happened to have a ti-86 & need some help.
I understand how to calculate the mean by hand & by the calculator for most circumstances. What I don't is when there are classes, for example
Class Frequency
10-19 8
20-29 16
30-39 21
40-49 11
50-59 4
Now, I can compute the approximate mean by hand with the formula in the book. The answer gives a mean = 32.83 & a standard deviation = 11.06. The answer checks with the back of the book. How can I place this information into the ti-86 & get the same results?
You will have to enter a list. To solve the following problem, Enter a list of 8 15s 16 25s 21 35s etc. Then you can pull all the 1-Var Stats of this list. It should give you the proper mean, and variance.
Thanks for the help, what actually happened was I was getting the xstat & ystat mixed up with fstat... The classes as you pointed had to be placed in the xstat & then the frequency in the fstat. Seems kinda silly, not sure why I didn't get it before.
  • · Replies 18 ·
15K
