Calculate Acceleration & Velocity of Motion Under Gravity
  • Context: High School
  • Thread starter Thread starter math4me
    Gravity Motion
The discussion revolves around calculating acceleration and velocity from experimental data of a cylinder rolling down a ramp. Participants explore the relationships between distance, time, acceleration, and velocity, focusing on the application of kinematic equations.
  • Homework-related
  • One participant presents a dataset of distances and corresponding times, seeking help to calculate acceleration and velocity.
  • Another participant suggests using the kinematic equation x(t) = x_0 + v_0t + (1/2)at^2 to derive acceleration, noting that initial conditions are zero.
  • A third participant emphasizes the need for two time intervals to calculate acceleration, explaining the relationship between position, velocity, and acceleration as derivatives of order.
  • Specific calculations for velocity and acceleration are provided using the dataset, illustrating the changing nature of velocity and implying the presence of acceleration.
  • Some participants express confusion regarding the questions posed, indicating a lack of clarity in the initial request for help.
Participants do not reach a consensus on the calculations or the clarity of the initial inquiry. Multiple approaches to calculating acceleration and velocity are discussed, but no single method is universally accepted.
The discussion highlights the complexity of deriving acceleration from discrete data points and the necessity of understanding the order of derivatives in relation to time intervals. Some assumptions about the continuity of motion and the applicability of kinematic equations are not explicitly stated.
math4me
I would really appreciate some help on this please:
Distance in metres
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
Time talen to travel distance (in seconds)
0.72
1.28
1.67
1.85
2.08
2.50
2.83
3.01
3.13
3.25
What would you expect the accelartion to be and also what would you expect the velocity to be?
Mass = 0.164 Kg
Inital velocity = 0.
The experiment was letting a cylinder roll down the ramp and the data is above.
I just can't seem to calculate the acceleration and velocity could someone please help me thank you very much (much appreciated).
You know that:
[tex]x(t) = x_0 + v_0t + \frac{1}{2}at^2[/tex]
You have three variables, x0, v0 and a. You already know that x0 and v0 are zero, so that leaves you with:
[tex]x(t) = \frac{1}{2}at^2[/tex]
To find the acceleration just use one of the measurements, for example 1m and 3.25s:
[tex]1m = \frac{1}{2}a(3.25s)^2[/tex]
As for calculating the velocity, that is just:
[tex]v(t) = v_0 + at[/tex]
The value of t varies depending on when you want to find the velocity.
At the last point the final velocity, so what would the acceleration be, not to clude up on the equation(s).
Thank you very much
Anybody please tyty.
I don't understand your questions.
In a discrete set of data, acceleration will require two time intervals, since it is a second order derivative.
(note: position is zeroth order, and does not require an interval, just a point; velocity is first order, and therefore requires one time interval, that is, two points; every order of time derivative, requires that many time intervals to specify)
You have 9 time intervals, so, you have 8 meaningful accelerations. I'll give you an example:
(t,x)0 = (0.1,0.72)
(t,x)1 = (0.2,1.28)
(t,x)2 = (0.3,1.67)
This gives you three positions (three null intervals), two velocities (2 x 1 interval), and one acceleration (1 x 2 intervals). The velocity is the space interval divided by the time interval from one point to the next:
v0 = (x1 - x0)/(t1 - t0) = (1.28 - 0.72)/(0.2 - 0.1) = 5.6
v1 = (x2 - x1)/(t2 - t1) = (1.67 - 1.28)/(0.3 - 0.1) = 3.9
Notice that the velocity is changing, thus, there is an acceleration.
a0 = (v1 - v0)/(t1 - t0) = (3.9 - 5.6)/(0.2 - 0.1) = -17
There are also other ways to do it.
Notice the similarity in:
x'(t) = lim(as dt -> 0){x(t+dt)-x(t)}/{(t+dt)-t}
The discrete treatment given above is a consequence of not taking the limit.
15K
