Determining Length of Sequence for Modulation Techniques
The discussion focuses on determining the length of a sequence for modulation techniques, specifically in the context of QPSK (Quadrature Phase Shift Keying). The key formula presented is: (number_cycles_per_sequence/number_periods_per_symbol) * number_bit_per_symbol = total number of bits per sequence. The user, Hanan, seeks clarification on how to decide the value of number_periods_per_symbol, which is crucial for both modulation and demodulation processes. Additionally, the conversation highlights the importance of selecting an appropriate digital communication protocol, such as TCP/IP, RS232, or USB, which impacts the overall transmission process.
  • Understanding of QPSK modulation techniques
  • Knowledge of digital communication protocols (e.g., TCP/IP, RS232, USB)
  • Familiarity with binary representation of messages
  • Basic concepts of modulation and demodulation processes
  • Research the mathematical foundations of QPSK modulation
  • Learn about the role of number_periods_per_symbol in modulation
  • Explore different digital communication protocols and their overheads
  • Study error correction techniques in digital communications
Engineers and students in telecommunications, digital signal processing professionals, and anyone involved in designing or optimizing modulation techniques for data transmission.
hananl
Hello,
I need help with modulation techniques.
If I have a sequence I want to transmit, and need to be modulated, how do I know its length? :
I know the time duration of the sequence=t => t/T(carrier period)=number of cycles per sequence.
(number_cycles_per_sequence/number_periods_per_symbol)*number_bit_per_symbol = total number of bits per sequence.
1) So, now my question is, how do I decide the value of number_periods_per_symbol?
I guess I also need this value for the symbol clock when demodulation, no?
2) when I create modulation - I modulate the sequence of bits. How long will take each 2 bits (one symbol=2 bits for qpsk)? that's exactly the question in 1, right? - deciding number_periods_per_symbols?
So this value I guess must be somewhere in the formula for creating the qpsk modulation?
Regards,
Hanan.
It is a two step process.
First, figure out how to express your message in binary.
Then, look for a digital communication protocol. Each protocol has overhead to allow for start/stop off the messsage, error correction, routing and so forth. TCP/IP is a very complicated protocol for sending data over the Internet. RS232 and USB are simpler serial protocols. You must choose one.
10K
  • · Replies 92 ·
