Delta-Epsilon Limit Test for Sqrt(X) > 0
  • Thread starter Thread starter olds442
    Limit
The discussion centers on proving the limit of the square root function using the Delta-Epsilon limit test for the sequence \(X_n\) converging to \(X\), specifically when \(X > 0\). The user seeks guidance on applying the Delta-Epsilon method after establishing that \(|\sqrt{X_n} - \sqrt{X}| < \epsilon\). The conversation highlights the need for clarity in notation and emphasizes the importance of correctly manipulating inequalities to complete the proof. The proof for the case where \(X = 0\ is straightforward, but the challenge lies in the case where \(X > 0\.
  • Understanding of the Delta-Epsilon definition of limits
  • Familiarity with sequences and convergence in real analysis
  • Knowledge of properties of square roots and inequalities
  • Basic proficiency in mathematical notation and LaTeX formatting
  • Study the Delta-Epsilon limit proof techniques in detail
  • Review convergence of sequences in real analysis
  • Practice manipulating inequalities involving square roots
  • Explore examples of limits involving continuous functions
Students of real analysis, particularly those learning about limits and convergence, as well as educators seeking to clarify the Delta-Epsilon method for teaching purposes.
olds442
Ok, so I was reading my Real Analysis Text and there was a proof that Lim sqrt(Xn)=Lim sqrt (X). They had two cases, one where Xn=0 where they use the Delta-Epsilon limit test and it makes perfect sense to me. However, they also show the example where x>0. obviously since x>0, Sqrt(x) is also >0. They prove it without using the E-D method and I am trying to prove it using it. Ill show my first few calculations ill use S(Xn) to denote sq. rt. and e to denote epsilon:
e>0 is given
|S(Xn)-S(x)|<e after multiplying by (S(Xn)+S(x))/(S(Xn)+S(x)) i get: Xn-X/(S(Xn)+S(x))<e now it would also be true that Xn-X/(S(Xn)<e from here, i do not know how to continue the proof in order to solve for it. If i squared both sides, i would have a nasty polynomial on top and that wouldn't offer much help.. any advice?
thanks
Welcome to PF olds442.
Your notation is not very clear, so let us first find out what you meant :smile:
I suppose you meant we have a sequence [itex](X_n)_{n \in \mathbb{N}}[/itex] of real numbers whose limit for n to infinity is X, and you want to prove that
[tex]\lim_{n \to \infty} \sqrt{X_n} = \lim_{n \to \infty} \sqrt{X},[/tex]
which is [itex]\sqrt{X}[/itex].
What do you mean by "Xn = 0", that each element in the sequence is zero (for all n?). Then you talk about x > 0, what is x? Is it X ?
I am sorry for the terrible notation.. Your latex example is what i meant. Here is how it is written: Let X= (Xn) be the sequence of real numbers that converges to x and suppose that Xn is greater or equal to 0. Then the sequence Sqrt(Xn) of positive roots converges an lim(sqrt(Xn)=sqrt(x)
It proves the case where x=0 using d-e, and i get that no problem.. i am having problems simplifying and showing the limit for the case where x is strictly greater than 0 using d-e. does that help? sorry for tripping you up with poor notation.. i am a rookie at trying to type it on computers!
  • · Replies 31 ·
12K
