A toy car has a mass of 120g, including two 1.5V batteries connected in series.
The discussion revolves around a toy car with a mass of 120g, which includes two 1.5V batteries connected in series. The problem involves calculating the charge that passes through the batteries as the car accelerates from rest to a speed of 1.5 m/s, considering the motor's efficiency and neglecting friction and air resistance.
  • Participants explore the relationship between kinetic energy and the charge passing through the batteries. They discuss the equations related to power, energy, and charge, while questioning the need for time in the calculations.
Participants have provided various approaches to relate kinetic energy to electrical energy and charge. Some have confirmed calculations while others have corrected minor errors. There is an ongoing exploration of the relationships between the different forms of energy involved.
There are mentions of potential confusion regarding mass units and the importance of efficiency in the calculations. The discussion also highlights the need for clarity on the definitions and relationships between energy, power, and charge.
Xaspire88
A toy car has a mass of 120g, including two 1.5V batteries connected in series. Suppose the motor that drives the car is 80% efficient (i.e., 80% of the electric energy goes to the drive wheels, 20% is dissipated as heat) and that friction and air resistance are negligible. How much charge passes through the batteries during the time it takes the car to accelerate from rest to 1.5 m/s?
I thought i might be using these equations somehow. Not entirely sure though.
P=IE
I=[tex]\Delta[/tex]Q/[tex]\Delta[/tex]t ?
I'm really having a hard time knowing where to begin. Any hints or thought provoking questions would help. I suppose i need to find out the amount of time it takes for the car to accelerate to that velocity first but i really have no idea how to begin.
What type of energy the car (including battery) is gaining ?
What's the relation between that type of energy and the required speed (1.5 m/s) ?
Figure this out and you might question the need of knowing the time that it takes.
Correct me if I am wrong.
http://ghazi.bousselmi.googlepages.com/présentation2
its gaining kinetic energy. KE= 1/2mv^2 i have a mass of 120g Velocity of 1.5m/s ... so
KE = 1/2 (0.12Kg)(1.5)^2 = 0.27
sorry had my decimal in the wrong place.. its 0.12kg not 1.2kg.
And the electrical power, P = current * volts. Energy is power * time and charge is current * time.
So electrical energy E = I * V * t and Q = I * t
careful, it's 120g not 1.2kg.
nice, now what's the relation between that KE (at that speed) and the total charge that passed through the battery ?
well knowing that E=IVt and Q=IT i can substitute Q for IT in the equation E=ItV and have E=QV
i have a E of .27 and a total voltage of 3.0V? (two 1.5V batteries) .27/3=Q= 0.09 C?
looks to me that you forgot the "1/2".
The rest of calculations is right.
how very right you are :). Thank you. It's always the simple things. so my Ke= .135 then and so .135/3=Q= 0.045 C? Would that be correct?
Ok. Thank you guys.
  • · Replies 28 ·
10K
