Uncertainty principle and ice pick
The discussion focuses on estimating the time an ice pick can be balanced on its tip, constrained by the Heisenberg uncertainty principle. The user proposes using a mass of 0.5 kg for the ice pick and a tip dimension of 1x10-3 m. By applying the uncertainty principle formula, they calculate a velocity of 1.05457148 x 10-31 m/s. The user seeks guidance on whether their approach is correct and how to proceed with estimating the time until the ice pick falls.
  • Understanding of the Heisenberg uncertainty principle
  • Basic knowledge of physics, particularly mechanics
  • Familiarity with dimensional analysis
  • Ability to perform calculations involving mass and velocity
  • Research the implications of the Heisenberg uncertainty principle in practical scenarios
  • Learn about calculating time of fall using kinematic equations
  • Explore the concept of stability in physics, particularly for balancing objects
  • Investigate the effects of mass and surface friction on balance time
Physics students, hobbyists interested in mechanics, and anyone exploring the intersection of quantum mechanics and classical physics applications.
indigojoker
I need to estimate the amount of time that an ice pick can be balanced at it's tip and the only limitation is set by the Heisenberg uncertainty principle. I assume the tip is sharp and the surface that the tip rests on is hard. I can also assume values of dimensions and weight as long as the this does not change the general order of magnitude of the result. The result must also be in seconds.
I really have no clue where to start. Someone throw me a bone:rolleyes:
i was thinking something like this:
mass of ice pick [tex]m=0.5 kg[/tex]
the tip of the ice pick is about [tex]\Delta x = 1x10^{-3} m[/tex]
plug into uncertainty principle:
[tex]\Delta x \Delta p >= \frac{\hbar }{2}[/tex]
[tex]\Delta v >= \frac{\hbar}{2 (1x10^{-3} m)(0.5 kg)}[/tex]
[tex]\Delta v >= 1.05457148 x 10^{-31} m/s[/tex]
then i can estimate a distance that the pen has to move for it to fall and then divide that by the velocity above?
not sure if I'm on the right path, any help would be greatly appreciated :)
  • · Replies 32 ·
  • · Replies 16 ·
