Solve Car Chase Question: 110 km/h and 170 km/h
  • Thread starter Thread starter anglum
    Car
The discussion revolves around a physics problem involving a speeder and a cop car, where the speeder travels at a constant speed of 110 km/h and the cop car accelerates from rest at 9 km/h² until it reaches a maximum speed of 170 km/h. Participants are trying to determine how long it takes for the cop car to catch up with the speeder, with various attempts to relate their distances and times.
  • Participants discuss the equal distances traveled by both vehicles and explore the necessary formulas to relate their speeds and times. There are questions about how to handle the conversion of units and the implications of acceleration on distance. Some participants suggest calculating the time it takes for the cop car to reach its maximum speed and the distance covered during that time.
There is ongoing exploration of the problem with various participants offering insights and calculations. Some have provided partial calculations and suggestions for further steps, while others express confusion about unit conversions and the overall approach. Multiple interpretations of the problem are being considered, and participants are actively engaging with each other's ideas.
Participants are grappling with the conversion of speeds from km/h to km/s and the implications of acceleration on the distances traveled. There is also a mention of the initial conditions of the problem, including the cop car starting from rest and the need to determine the initial distance between the two vehicles.
anglum
A speeder traveling 110 km/h races past a cop car. The cop car is at rest and pursues at acceleration of 9km/h until it reaches its maximum speed of 170km/h until it catches up with the speeder. How long does it take the cop car to catch the speeder answer in units of seconds
i know the distance the 2 travel is equal
so for the speeder d = 110/t
and for the cop car i should use what formula so that i can relate them to d=d
so that 11/t = the distance formula for the cop car
what should my next steps be?? please help me
can someone point me in thee right direction so i can start tryin to solve this the correct way
learningphysics can you help me
I recommend first find out the distance between the two cars, when the cop car has reached 170km/hr...
How long does it take the cop car to reach 170km/h? Over what distance does this happen?
How long has the speeder traveled in this time?
ok so the time for the cop car to get to 170 km/h is
170/9 = 18.8888 is that in seconds then?
so then in 18.88 seconds the otehr car would have gone .577133 km?
anglum said:
ok the time it takes the cop to reach the 170 km/h is 18.888 seconds... but I am not sure how to calculate how long it takess him to catch the other car please help
What distance has the cop traveled in 18.888 seconds? What distance has the speeder driven in 18.888s?
i am gettin screwed up becuz the speeds are in km/h and the time is in seconds GRRR i suck
ok so am i right in my sayin it takes the cop 18.88 seconds to reach 170 km/h
and then i converted 170 to km/s aand got .0472 km/s
and i converted 110 km/h to km/s and got .03055 km/s
then the distance the speeder went was .57713 km
and the distance for the cop is what?
Is the acceleration 9km/h per second? What exactly is the acceleration given?
yes that is the acceleration
For the cop, you'd use:
d = v1*t + (1/2)at^2. here v1 = 0. convert 9km/hr per second into km/s^2...
the distance the cop travels then is.445568 km after 18.88 seconds
so now i knwo they are .131562 km apart at that time
so now what do i do to solve for the time of the cop car to catch the speeder
so i then get this
cop ---- d+.131562 = .0472km/s (t)
speeder ---- d = .03055km/s (t)
so then i can say that .0472t - .131562 = .03055t ?
yes. that looks right... at the end remember to add 18.888s to whatever you get here to get total time.
so the total time it takes to catch the speeder is 26.7896 seconds
now to find the total distance each car traveled i simply take
d = .03055km/s (26.7896) or d +.131562 = .0472km/s (26.7896) ?
cuz if i do that the distances are different
Take the speeder's velocity times the total time.
one more question regarding car chases learning if u don't mind
speeder goin 30.9 m/s
cop accelerates at 2.49m/s squared
how long until he catches speeder
so again the distances and times are equal for the two cars correct?
Like you said initially all you need is a distance formula for the cop car...
final velocity squared - initial velocity squared = 2 * distance * acceleration
so for the cop: 170 - 0 = 2 * d * 9
just solve for distance and then use that in your initial equation for the speeder.
my other problem is ...
speeder goes by cop at 30.9m/s
how logn till he catches speeder
again the distance the 2 travel and the time they travel is the same correct?
so what equation should i solve since i don't know how far ahead the speeder is this time?
same type of thing as before... The position of the speeder is 30.9t.
What is the position of the cop car?
set the two positions equal. Solve for time.
the position of the cop car is .5(2.49)tsquared
if i set them to equal i don't know how to solve for t?
sorry (170*170) - 0 = 2 * d * 9 ... then solve for distance and use this to calculate the time.
or is that wrong for the position of cop car?
0.5(2.49)t^2 = 30.9t
1.245t^2 = 30.9t
1.245t^2 - 30.9t = 0
t(1.245t - 30.9) = 0
ok but once it gets to that point how do i solve for t from there
t(1.245t -30.9) = 0
wont anything i solve equal 0 ... grr i need to stop doing theese late at nite when my brain is fried
t(1.245t -30.9) = 0
When you have ABC... = 0, that means A = 0 or B = 0 or C = 0 etc...
t(1.245t -30.9) = 0
implies:
t = 0 or 1.245t - 30.9 = 0
the t = 0 is at the start... it's not the solution you need. solve: 1.245t - 30.9 = 0.
ok so when solving that i get
t = 24.81927711 seconds? is that correct?
  • · Replies 20 ·
  • · Replies 18 ·
9K
