How Does Charge Distribution Affect Electric Fields in Concentric Spheres?
  • Thread starter Thread starter Arisa
    Conducting Sphere
The discussion focuses on the electric field distribution around concentric conducting spheres. A solid conducting sphere with charge +q and radius a is enclosed by a hollow conducting sphere with inner radius b and outer radius c. The electric field is derived as follows: for rc, E = [1/(4*pi*epsilon_0)](q/r^2). The charge distribution results in a -q induced charge on the inner surface of the hollow sphere and a +q charge on its outer surface, leading to the cancellation of electric fields in specific regions.
  • Understanding of electrostatics and electric fields
  • Familiarity with Gauss's Law
  • Knowledge of charge distribution in conductors
  • Basic calculus for deriving electric field equations
  • Study Gauss's Law applications in electrostatics
  • Learn about electric field calculations for spherical charge distributions
  • Explore the concept of surface charge density in conductors
  • Investigate the behavior of electric fields in different geometrical configurations
Students of physics, particularly those studying electrostatics, electrical engineers, and educators seeking to understand charge distribution in concentric spheres.
Arisa
A solid conducting sphere carrying charge q has radius a. It is inside a concentric hollow conducting sphere with inner radius b and outer radius c. The hollow sphere has not net chare. a) Derive expressions for the electric field magnitude in terms of the distance r from the center for the regions r<a, a<r<b, b<r<c, r>c.
I've managed to correctly answer the first two parts of the problem, however when it comes to b<r<c and r>c, I do not get the answers I should.
Apparently, for b<r<c, E = 0 since a -q cancels the inner +q. Then, for r>c, E = [1/(4*pi*epsilon_0)](q/r^2) since the total charge enclosed is +q again.
I think my problem lies in the fact that I don't fully comprehend what a concentric sphere is or how charge distribution on a concentric sphere works. Based on the solution, I feel I should intrepret that the neutral concentric sphere is neutral because it contain an equal number of positive and negative charges that have all collected on opposite surfaces - the negative charges on the inner surface of the concentric sphere (radius b) and the positive charges on its outer surface (radius c.) Otherwise, I don't quite understand how the -q and overall +q come into play...
Thank you very much for taking the time to read this!
This might help - http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html
The inner sphere has charge +q. Being a conductor, the charge resides at the surface.
It would have a surface charge density of +q/4[itex]\pi[/itex] a2.
This positive charge induces a corresponding -q charge on the inner surface of the hollow conductor (r=b), and consequently there is a +q charge on the outer surface r = c.
The electric flux is based on the enclosed charge, and the +q at r=a cancels the -q charge at r=b.
Then there is a charge +q at r=c.
The surface density of the charge at r = b is -q / 4[itex]\pi[/itex] b2, and the surface charge density at r=c is +q / 4[itex]\pi[/itex] c2.
  • · Replies 18 ·
