Thread Closed
Functions, operator => eigenfunction, eigenvalue
Share Thread Thread Tools
Sep24-07, 05:57 AM   #1
Show, that functions
f1 = A*sin([tex]\theta[/tex])exp[i[tex]\phi[/tex]] and
f2 = B(3cos[tex]^{2}[/tex]([tex]\theta[/tex]) - 1) A,B - constants
are eigenfunctions of an operator
and find eigenvalues
3. The attempt at a solution
This is what i got for the first function:
The next step is to solve left part of the equation, and than compare it to the right part.
The question arises, how to solve that equation?
I tried simplifying left part of an equation in mathcad, and I got
Next question from that part, is if I am doing it right, how to compare those parts, and answer a question - weather this function is an eigenfunction of an operator?
Thank You in advance, and I am constantly near computer and waiting for suggestions.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep24-07, 09:24 AM   #2
Your eigen operator has partial derivatives wrt to [itex]\theta[/itex] and [itex]\phi[/itex]. When you operate it on your given eigen function, you should get back your original function multiplied by a scaling factor which is your eigenvalue.
Sep24-07, 11:25 AM   #3
Yes, Thank You, but how do I calculate that? May I ask for instructions on how to calculate that left part of an equation? Is the result I got is correct?
Sep24-07, 11:32 AM   #4
Recognitions:
Homework Helper Homework Help
Quote by sundriedtomato View Post
Just go ahead and apply the derivatives!! It's that simple. (btw, I don't know what you entered in mathcad but what it gave you is wrong).
all you have to do is to apply the derivatives
Sep24-07, 11:34 AM   #5
Recognitions:
For the first term, what you have to calculate is
[tex] \frac{1}{sin \theta} \frac{\partial}{\partial \theta} ( sin \theta ~\frac{\partial}{ \partial \theta} (A sin \theta} e^{i \phi}}) ) [/tex]
Sep24-07, 12:37 PM   #6
I will give it a try right know. Thank You.
Sep24-07, 01:58 PM   #7
So, after proper calculations, the result is
Is this one correct?
I posted an image of what I am given, and as far as I know, differentiation sign usually is placed before the function?
I just don't get it - to what parts of an equation do underlined derivatives belong t?
Thank You.
Sep24-07, 09:27 PM   #8
The part in brackets is an "operator"... every incomplete differentiation sign (ie, without anything to differentiate) operates on whatever is "multiplied" to it.
For example, the d/d(theta) is your image also operates on A*sin(theta)*exp(i*phi), because when you open the bracket, it gets to differentiate that term.
Eg. (the d's are partial)
[d/dx + d/dy]*x*y^2 = y^2 + 2*y*x
Sep25-07, 02:46 AM   #9
Sep25-07, 08:21 AM   #10
Just operate it on the function. They are simple partial derivatives, I won't take much time to solve. Just a little patience for the initial steps. I tried your problem and many terms get canceled out and you get the solution correctly. You don't need mathcad to do it.
Sep25-07, 11:04 AM   #11
Thank You Reshma! I already managed to solve it correctly, and find eigenvalues as well.
For the case with the first function : a = 2h^2, and for the case with second function b = 6h^2. The problem was initially in understanding how to apply operator properly. Once example have been given, and operator properties reanalyzed - problem got solved in like 10 minutes (with putting it all on a paper as well). Thank You everybody who took part in this one!
Thread Closed
Thread Tools
Similar Threads for: Functions, operator => eigenfunction, eigenvalue
Thread Forum Replies
Eigenfunction, Eigenvalue, Wave Function and collapse Quantum Physics 0
Eigenfunction of an Operator Advanced Physics Homework 7
QM - Eigenfunction / Eigenvalue Problem Advanced Physics Homework 2
hey,guys is ther a thing name after the eigenfunction of the time operator Quantum Physics 16
