How is a rocket's orientation determined during wind tunnel testing?
The discussion revolves around the orientation of rockets during wind tunnel testing, exploring how this orientation affects the testing of aerodynamic forces and moments. Participants consider different scenarios, such as testing in flight versus on the launch pad, and the implications for data collection and analysis.
  • One participant questions whether rockets should be mounted vertically or horizontally in a wind tunnel, comparing it to airplane testing.
  • Another participant suggests that for flight testing, rockets should be pointed into the wind like aircraft, while vertical mounting may be appropriate for testing structural integrity on the launch pad.
  • A different viewpoint emphasizes that the lift and drag characteristics are independent of the model's weight, indicating that the orientation of the wind tunnel is not necessary for measuring these forces.
  • One participant clarifies that the model's orientation should reflect the specific characteristics being investigated, with the wind tunnel flow remaining constant.
Participants express differing opinions on the appropriate orientation for wind tunnel testing of rockets, indicating that multiple competing views remain on this topic.
Participants discuss the implications of model orientation on data collection but do not resolve the specifics of how to approach different testing scenarios.
Rattboi
How does a rocket get tested in a wind tunnel? what is it's orientation?
an airplane is facing the air, like in reality, as it flies. so does that mean you mount a rocket vertically, but have the wind come on the side? or do you mount it pointing in the direction of the wind?
and does that mean you have to rotate everything around when you are building the forces and moments database?
If you are testing it in flight you point it into the wind in the same way as an aircraft (ie horizontally). I suppose you could mount it vertically if you are trying to find out what happens when it is on the pad and the wind is blowing past it.
Main difficulty is probably finding a supersonic wind tunnel.
The lift, drag, and air flow patterns around an aircraft (for a given wind speed and angle of attack) are unaffected by the weight of the aircraft. Of course, the weight of the model in the wind tunnel must be known simply so it can be subtracted from the measured downward force while it is in the wind tunnel. After all these other forces and the various flow patterns are discovered, then one can easily ask questions like, "will that lift be enough to hold up an aircraft of a certain weight?". So it isn't necessary to orient the wind tunnel.
Here are a couple of pictures for you. Like was already mentioned, the orientation of the model is such that whatever it is you are investigating is what is happening. If you are interested in flight characteristics, then it is mounted pointing into the flow of the tunnel. If you want to know about structural issues when it is on the launch pad, then you would orient it perpendicular to the flow. The main thing is is that the model orientation changes. The tunnel does not.
http://web.mit.edu/cats/www/photos/2002/2002_IAP/Jan29_Carl/Carl_slide1.jpg
http://www.staynehoff.net/saturnv-aedc.jpg
15K
15K
